New Surface Dock Does Not Work via mini displayport to HDMI & DVI
2015-10-27T17:18:04+00:00
The specific device I am referring to, is the new Surface Dock for Surface Pro 3/4 and Surface Book. I have described the issue here on Reddit, and a number of others are also experiencing the same problem. Basically, the new dock doesn't work when the monitor is connected using mini displayport to HDMI. The monitor is detected correctly and the correct resolution is set, but the screen remains black. In my case, I randomly get some image on the monitor, but it's compressed to one side of the screen and garbled. The mini displayport to HDMI adapter works properly when connected directly to the Surface, so the adapter itself is fine. If I instead connect the mini displayport to VGA adapter to the dock, the monitor displays correctly. I have tried using a straight mini displayport to DVI cable and the issue remains. Additionally, I have connected a Surface Pro 3 to the dock and experience the same issue.
So to summarize, the dock does not function correctly when using a mini displayport to HDMI adapter to connect the monitor, but does work with a mini displayport to VGA adapter. This problem is repeatable using both a Surface Book and Surface Pro 3.
2015-10-29T17:45:57+00:00
I purchased an active mDP to HDMI adapter from Amazon (Plugable is the brand) and so far the external monitor is working correctly through the dock.
Moderator Edit (11/3/2015):  If you are using a passive MDP to DVI adapter and experiencing difficulties, you may need to switch to using an active adapter.
If you switched from a passive to active adapter and continue to experience difficulties using Surface Dock to display to external monitors please consider making some changes to your cabling: different lengths, different quality, different adapters, etc.  If adjusting your cabling fails to resolve please consider sharing the following:
  1. Make and model of external displays
  2. Make/model of adapters if present
  3. Make/model of cables
For more troubleshooting info and steps to confirm your Dock is updated, please view our Troubleshoot Surface Dock article.
Thank you,
Josh
2017-05-22T09:18:50+00:00
 We suggest that you contact our Surface Answer Desk team for further assistance or visit the nearest Microsoft Store if you are in the US. In case you're offshore, contact our Global Customer Service team.
315 additional answers
    2015-12-10T21:42:07+00:00
    I initially had the same issue with 2x external ASUS 27in monitors.  I use 2x mini DP to HDMI adapter on the 2 display ports with the new dock.   The old cables and the monitors worked perfect on another computer.   Just of curiosity,  I changed both HDMI cables to 2 new HDMI cables with 2.0/1.4 compatibility and certified 4K support,  it started to work pretty stable.
    I have Surface book i7/16GB/512GB with the new surface dock and 2x mDP to HDMI adapters.  Everything works good with 2x external 27in monitors.
    2015-12-10T22:52:09+00:00
    Had same issue and just replaced one Mini DisplayPort passive adapter with active (to match the other which was active and working).  Problem seems solved but I'll "monitor" it for a few reboots and disconnections and see how it goes.
    2015-12-11T14:56:48+00:00
    Split from this thread.
    Hi, same issue with Surface Book - it looks that MSFT did not do much progress on this field.
    No problem when connecting monitor directly to Surface Book and random response when trying to connect monitor through the docking station. I've tried with 3 different monitor, with 3 different mini-connectors, using HDMI and Display Ports in the monitor, restarting whole stuff etc. Sometimes, randomly the monitor was detected and working, however in 99% cases it was not a case.
    In case of Surface Book it is even more frustrating, because MSFT intentionally disabled usage of minidisplay port in the Book when it is connected to the docking station...
