New Surface Dock Does Not Work via mini displayport to HDMI & DVI
2015-10-27T17:18:04+00:00
The specific device I am referring to, is the new Surface Dock for Surface Pro 3/4 and Surface Book. I have described the issue here on Reddit, and a number of others are also experiencing the same problem. Basically, the new dock doesn't work when the monitor is connected using mini displayport to HDMI. The monitor is detected correctly and the correct resolution is set, but the screen remains black. In my case, I randomly get some image on the monitor, but it's compressed to one side of the screen and garbled. The mini displayport to HDMI adapter works properly when connected directly to the Surface, so the adapter itself is fine. If I instead connect the mini displayport to VGA adapter to the dock, the monitor displays correctly. I have tried using a straight mini displayport to DVI cable and the issue remains. Additionally, I have connected a Surface Pro 3 to the dock and experience the same issue.
So to summarize, the dock does not function correctly when using a mini displayport to HDMI adapter to connect the monitor, but does work with a mini displayport to VGA adapter. This problem is repeatable using both a Surface Book and Surface Pro 3.
2015-10-29T17:45:57+00:00
I purchased an active mDP to HDMI adapter from Amazon (Plugable is the brand) and so far the external monitor is working correctly through the dock.
Moderator Edit (11/3/2015):  If you are using a passive MDP to DVI adapter and experiencing difficulties, you may need to switch to using an active adapter.
If you switched from a passive to active adapter and continue to experience difficulties using Surface Dock to display to external monitors please consider making some changes to your cabling: different lengths, different quality, different adapters, etc.  If adjusting your cabling fails to resolve please consider sharing the following:
  1. Make and model of external displays
  2. Make/model of adapters if present
  3. Make/model of cables
For more troubleshooting info and steps to confirm your Dock is updated, please view our Troubleshoot Surface Dock article.
Thank you,
Josh
2017-05-22T09:18:50+00:00
 We suggest that you contact our Surface Answer Desk team for further assistance or visit the nearest Microsoft Store if you are in the US. In case you're offshore, contact our Global Customer Service team.
315 additional answers
  1. Deleted
    2016-04-05T19:48:16+00:00
    When I bought my Surface Pro 4 from Best Buy in October 2015, They sold me the Insignia Display Adapters for HDMI and VGA. They both worked perfectly at home and at the office until after a system upgrade about a month ago. The VGA adapter quit working on any VGA monitor except, curiously, a projector in the conference room at my office.
    I took the VGA Adapter back to Best Buy and they couldn't get it to work on a Surface Pro 4 there, so I exchanged it for a Microsoft Brand VGA Adapter and then everything worked fine again.
    As of last night, the HDMI connection quit working on my home monitor, so I assume maybe Microsoft has done a system update that now makes that one incompatible? Later today I plan to return to Best Buy to try the Microsoft version and turn in the Insignia if that solves the problem for HDMI.
    Anyone else with similar experience?
    2016-04-05T19:44:48+00:00
    This isn't a fix for the dock, but I have a workaround that's working about 90-95% for me.  For now, I've basically chucked the dock and am using a 2-port mini displayport hub.  The hub I'm using is a StarTech MSTMDP122DP.  I plug that into the mDP port on the Surface Book and plug my two DP monitor cables into the hub.  This setup has been pretty solid for me.
