Can I connect Surface RT and PC with USB cable?
2012-11-30T00:08:13+00:00
I have a Toshiba Thrive running Android. I can connect it to my PC with a USB cable and access files on my Thrive on the PC. The PC treats the Thrive as a hard drive. Can I connect my Surface in the same way? I have tried and the PC does not appear to see the Surface.
This is a pain, one of the reasons I bought the Surface was to be able to do this type of hard connection and not have to use "iTunes" or the Cloud.
Surface | Other
2013-03-05T02:57:40+00:00
Greetings SaeedR_706,
That is a good question, however I would suggest rather then using the USB cable, to transfer files over your WiFi network to a shared folder on your Windows 7 Laptop.
2012-12-05T00:46:39+00:00
Hello Rrccw,
No, you cannot connect the Surface to the PC via USB. However, you can setup Shared folderson your PC. Once you have that, have the Surface connect to the same network via WiFi and then go into Network from the Desktop app, select your PC and then see the Shared Folders. From there, the Surface should have Read/Write access if you gave the permissions on the PC.
65 additional answers
    2014-01-07T02:45:36+00:00
    Dominic, thanks for those work-arounds. It is appalling though that the Surface does not have this very basic functionality.  No wonder I'm the only person I know who has one. I want to transfer 20gb of photos from a recent holiday onto the Surface and use it as a digital photo frame. Every other tablet I've had I could just connect up to the PC USB port, drag and drop and it was done. To do this on the surface I have to do the same thing twice:
    1. Copy from PC to USB flash drive;
    2. Copy from USB flash drive to Surface.
    That automatically makes it take twice as long as any other device. That MS can think that that is OK shows a huge disrespect for their users. I won't even comment on the idea of crippling my net for the hours or days it would take to upload the 20GB of photos to Skydrive, to do something that would take minutes on any decent device. Sure there are other benefits to cloud storage but they are solutions to a different problem.
    Massive fail Microsoft! To think that I originally saw the USB port on the Surface as a positive. :(
    2014-01-07T02:52:50+00:00
    I totally realize that Wolfpup3. That is a technical answer though which totally disrespects users needs, which is precisely the problem that MS suffers.
    Almost all other PCs have an ethernet port, which avoids the crippling drawbacks of the wireless and two-step drive copying methods you've mentioned. If the Surface had an ethernet port this would be much less of a problem. As it is the Surface is neither fish nor fowl - it is just a tablet masquerading as a PC and as a consequence doing neither well. I'm certain that if MS cared they could build in some sort of client functionality to allow direct usb connection.
    2014-01-07T15:32:57+00:00
    It does not "disrespect users needs".  I'm just flabbergasted that you're trying to turn a GIGANTIC positive about Surface-the fact that it can actually function in many ways as a full PC into a negative.
    Ethernet doesn't change anything.  Either way this can be part of a Windows network.  Other tablets can't.  This can be connected to most any type of external storage.  Other tablets can't.
    You transfer files EXACTLY like you can from any PC...which you CAN'T do on any other tablet.
    I bought a Surface for a relative, and literally dropped it in where the notebook (and before that desktop) it was replacing sat, and RT worked with ALL the hardware that the previous PC was hooked to.  It works flawlessly with an external monitor, and with no intervention installed specific drivers for a printer, scanner, mouse and keyboard.  There is NO other tablet that can do that.  It's utterly awesome, and you want it crippled so that all it can do is function as a 'dumb' accessory for a PC?  What you're describing might be useful, but that's not how USB works, and Surface can do soooo much more than Android or iOS...
