My task bar is in normal position. The situation worsen when i use the stylus. The surface then repetitively black out. Cannot work. This is very new Surface.
Oh, I had this issue as well. When the pen is detected, the screen would black out for a second and turn back on when I remove the pen from the screen, then it blacks out again when I put it closer to the screen again. Mine would black out 2-3 times before resuming normal pen operation. Maybe try Windows Update, I know mine seems to have been fixed after a recent cumulative update on the Insider Dev channel, idk if stable build has received the update yet.
