Surface Dou - Fingerprint hardware not available
2021-05-21T20:18:35+00:00
I think after this latest update, my Duo's fingerprint just stopped working. The error i get is "Fingerprint hardware not available" any idea what i can do to get it working again?
Surface | Surface Duo | Safety and security
    2021-05-23T23:16:07+00:00
    Thanks for posting your concern here, ArtGarcia. We're sorry to learn about this issue on your device.
    In this case, it may be due to a software issue or possible hardware failure. Please try to Update Surface Duo or  Reset Surface Duo to factory settings. If issue persists, kindly contact Microsoft Surface Support to seek options for your device or possible replacement. If you're located outside United States, see Global Support.
    Best regards,
    StevenK
