9/29/2015 firmware caused wifi "device cannot be started"
2015-09-29T16:25:23+00:00
Split from this thread.
I have no idea what the update contained, other than the fact that it totally hosed my wifi. Device manager reports that the "device cannot be started". Wonderful.
Is it possible to go back to an older firmware version? If so, how?
How does something like this happen when a single company has complete control of both hardware and software? A complete lack of ability to execute a product, in my opinion.
Unbelievable, Microsoft!
Surface | Surface Laptop | Network
2015-10-05T11:18:35+00:00
On Mon, 5 Oct 2015 02:44:21 +0000, Arnold001 wrote:
>>I know that there was an update on Sept 30, and I find the coincidence too great that suddenly I got device error messages then and now my WiFi devices don't work.  Is there a fix coming?
If you've rebooted twice and there is no change, right now the fix is to do a
System Restore back to before this firmware update was installed.
Edit 10/06/2015: Two people have reported in that uninstalling Kaspersky fixes their issue.
Barb
Windows Experience MVP
2015-10-01T00:21:57+00:00
Hey all,
Thanks for sharing the details regarding your experiences with the Surface Firmware Update from 9/29.  Barb Bowman already mentioned to perform two (2) restarts so I'm just adding a little bit more to her advice (thanks Barb).
MODERATOR EDIT (10/6/2015): I am adding/updating steps to help address Wi-Fi availability after taking the 9/29/2015 Surface Firmware Update.
Step 1 – System Restore Point
1.    After Windows Update install, Surface will automatically request a restart (not shutdown).
2.    After Surface restarts, sign in and perform another restart (not Shutdown) to finish installing the update.  Press the Windows Start Menu, press Power and select Restart.
3.    After Surface restarts, sign in and see if you can now connect to your Wi-Fi network.
If you are able to connect to Wi-Fi, no additional steps are needed.  If you are not able to connect to Wi-Fi then go to step 2 below.
Step 2 – Uninstall the Wi-Fi Driver
1.    Right-click the Windows Start Menu and click Device Manager.
2.    Double-click on Network Adapters to expand the list of network adapters.
3.    Double-click on the Marvel AVASTAR network adapter.
4.    Click on the Driver tab.
5.    Click Uninstall.
6.    Make sure that “Delete the driver software for this device” is not checked.  Click OK.
7.    Click the Action menu and click Scan for hardware changes.
8.    Restart (not Shutdown) Surface.  Press the Windows Start Menu, press Power and select Restart.
If you are able to connect to Wi-Fi, no additional steps are needed.  If you are not able to connect to Wi-Fi then go to step 3 below.
Step 3 – System Restore Point
1.    Boot Surface using USB recovery media.  If you do not have recovery media you can download from here: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage.  Once you have recovery media proceed to next steps.  Note:  The USB drive must be formatted to FAT32 (not NTFS) in order to work correctly.
2.    Press and hold the volume-down button while you press and release the power button.  When the Surface logo appears release the volume-down button.
3.    When prompted select the language and keyboard layout you want.
4.    Select Troubleshoot, then Advanced Options, followed by selecting System Restore then select the target operating system.
5.    In System Restore, click Next.
6.    Click on a system restore point that was prior to applying the System Firmware update. Please use a restore point 9/28 or earlier.
7.    Click Next.
8.    Click Finish.
9.    Click Yes when asked if you want to continue.
10.    After moving to an earlier restore point you should boot into Windows.
Step 4 – Reset Surface to factory settings
1.    Follow the steps in the article below to boot Surface using USB recovery media and reset Surface back to factory settings:
http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/usbrecovery
As always, if this information doesn't address the missing WiFi scenario we want to hear from you.
Josh
P.S. We are working to manage your feedback and experiences with the blue screen after update here: https://answers.microsoft.com/en-us/surface/forum/surfpro3-surfusingwin10/repeated-bsod-after-firmware-update-surface-pro-3/529a1da2-3657-43f9-9af1-81c183650ce4.  Please post comments on the blue screen scenario in that thread.
155 additional answers
    2015-10-05T02:44:21+00:00
    I need some help...I'm currently using the Ethernet connection on my dock because somewhere around last week Tuesday or so, perhaps after an update, this computer no longer detects wireless networks.  In fact, there is no WiFi toggle in the network and internet tab in settings.
    I don't know exactly when this error first occurred.  I typically leave my computer at the office during the week.  I only now discovered that emails I tried to send Friday afternoon at home never went out because I didn't notice I didn't have an internet connection.  WiFi used to work perfectly.
    I've updated my computer, uninstalled the driver (and uninstalled the software), scanned my computer for new devices, and nothing.  In the device manager tab for the wireless adapter, in EVENTS, I found the following starting on Sept 30:
    Device Install Requested
    Device PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001&REV_00\4&28629041&0&00E0 requires further installation.
    Right after that, I found this event:
    Device Configured (oem241.inf)
    Device PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001&REV_00\4&28629041&0&00E0 was configured.
    Driver Name: oem241.inf
    Class Guid: {4D36E972-E325-11CE-BFC1-08002BE10318}
    Driver Date: 08/28/2015
    Driver Version: 15.68.9030.41
    Driver Provider: Marvell Semiconductor, Inc.
    Driver Section: mrvlpcie_Device.ndi.NTamd64
    Driver Rank: 0xFF0001
    Matching Device Id: PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001
    Outranked Drivers: mrvlpcie8897.inf:PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001:00FF0001 oem25.inf:PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001:00FF0001 mrvlpcie8897.inf:PCI\VEN_11AB&DEV_2B38:00FF2001 oem25.inf:PCI\VEN_11AB&DEV_2B38:00FF2001 oem241.inf:PCI\VEN_11AB&DEV_2B38:00FF2001
    Device Updated: true
    Then two more:
    Device Started(mrvlpcie8897)
    Device PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001&REV_00\4&28629041&0&00E0 was started.
    Service: mrvlpcie8897
    Lower Filters:
    Upper Filters: vwifibus
    and
    Device installed(mrvlpcie8897.inf)
    Driver Management concluded the process to install driver mrvlpcie8897.inf_amd64_2dd1e015b592f927\mrvlpcie8897.inf for Device Instance ID PCI\VEN_11AB&DEV_2B38&SUBSYS_045E0001&REV_00\4&28629041&0&00E0 with the following status: 0x0.
    After that, there's just a bunch of stuff from today where I deleted the device.  Those events were usually:
    Device Deleted
    Device Not Migrated
    Device Started (mrvlpcie8897)
    2015-10-05T02:48:52+00:00
    Even worse!  I've plugged my computer into my dock and used Ethernet to get the latest update installed.  I still don't have WiFi, and I can't roll back to previous versions.  Thanks, Microsoft.  Now I basically have a laptop circa 1995, but with no Ethernet port, so I only have connectivity at my office.
    2015-10-05T03:06:05+00:00
    One last clue:
    My phone allows for hotspots over USB, and I used to use this to get network connectivity when traveling.  Now, when I plug in the phone to the computer, personal hotspot doesn't activate.
    It looks like there's a serious problem with a network connectivity update on my computer.  The only thing that works is the Ethernet port on the surface pro dock.
