Surface Duo + Zwift
2021-01-23T02:07:44+00:00
Hello I was wondering if the Zwift app will run on the Surface Duo and has anybody here have had any experiences with it?
thanks.
Surface | Surface Duo | Operating system
2021-01-27T23:07:57+00:00
The Zwift app is available on the Google Play Store on the Surface Duo.
2021-01-27T02:40:22+00:00
Hello pinkrobot,
Thanks for keeping me posted. I'm sorry for the delayed response.
App pairing offers the users ability to use the split-screen feature to open two different applications on the device simultaneously. This means you can also do this on Duo as it has dual-screen productivity where you can do different things from each screen.
If this answers your question, please let our Community know by marking this post as an answer.
Kind regards,
StevenK
5 additional answers
    2021-01-28T03:36:29+00:00
    Thank you for the reply!
    2021-01-28T03:36:43+00:00
    Noted thank you!
