How do I setup 2 external monitors with Surface book 3 and Surface dock 4 thunderbolt?
2023-08-01T23:22:39+00:00
I have a Surface Book 3 running Windows 10. All Windows and graphics card drivers are up-to-date. I tried connecting two external monitors (Dell - S3222DGM 32" LED Curved QHD FreeSync Gaming Monitor) via USB-C to DisplayPort cables using the Surface Thunderbolt 4 Dock. Only one monitor is detected at a time ---- if I plug one in, the other doesn't appear. If I unplug the first and plug in the second, the second is detected, but the first isn't when I plug it back in.
Are there any other solutions? Or is this a limitation for this dock? And if so, does the surface dock 2 support multiple external monitors using a Surface Book 3?
Thank you!
Surface | Surface Book | USB-C
    2023-08-01T23:52:55+00:00
    Hi Christopher!
    Thanks for reaching Microsoft Community. We're here to help and let's work on this together.
    With your query, Surface Book 3 using Surface dock 4 thunderbolt would only be able to support 1 external monitor using USB-C cable. Surface Dock 2 would be your best compatible Surface Dock for your Surface Book 3. See through this link Buy Microsoft Surface Dock 2 – Microsoft Surface for more details and tech specs for Surface Dock 2.
    Hope this helps!
    Regards,
    RodelioP.
    2023-08-05T05:05:48+00:00
    Hi Christopher!
    We haven't heard from you in 72 hours, so we will consider your issue resolved. If you do need further help, please create a new thread to discuss your concerns through this link: Create a new question or start a discussion (microsoft.com) as we will not be monitoring this thread going forward.
    Thank you for understanding.
    Regards,
    RodelioP.
