I had this problem too. It only occurs when i am working on a metal table with the charger connected. If i put the laptop on the carrying pouch so it is completely separated frim the table then it stops. Am sure there are other causes too but there must be something causing interference. When i work on a standard wooden table it never happens. So worth checking other forms of interference around rheblaptop and charging cable if other solutions have not worked.
Surface Book 2 - Cursor freezes and mouse stops working randomly
Hi there :)
I post this to know if some other people are getting this issue too with the Surface Book 2 (15" model here).
Since the last firmware / drivers update (August 2018 / link), my mouse (G502, connected via USB) randomly stops working after a few seconds / minutes. The cursor just freezes, and the mouse becomes unresponsive (while the mouse is still powered by the Surface). After a while, the cursor starts to move again as usual.
Depending on the battery mode, the random freezes are more or less frequent (more if I use max performance mode), as the mouse cursor movement has an influence on the clockspeed of the processor.
I tried my mouse on a Macbook Pro to see if it was hardware related or not, and it's not, the cursor didn't hang once while on macOS. So I guess it's software related (W10) since the last SB2 update ?
I also tried to switch between the two USB ports, same thing.
I tried to see if it wasn't related to a firmware update of my mouse via the Logitech suite, but no nothing has changed.
Any idea ?
Regards :)
Ps : Here is a link to the Reddit post I wrote (link)
EDIT :
Today I tried to uninstall the Logitech Gaming Software (used to customize the mouse), and until now it seems to fix the issue.
Actually, Logitech did an update of his software that I missed, so I installed it a few hours after I installed the Surface Book 2 firmware update.
Maybe the two are now incompatible ?
2020-09-07T11:00:19+00:00 -
2020-10-08T04:56:06+00:00 powercfg -SETDCVALUEINDEX SCHEME_BALANCED SUB_PROCESSOR PROCFREQMAX 4000
powercfg -SETACVALUEINDEX SCHEME_BALANCED SUB_PROCESSOR PROCFREQMAX 4000
read this post for more details:
This method didn't work for me, even if I set it to 3800.
What a shame, for such a huge problem to stay unresolved for 2 years...
I updated my Surface Book 2 15'' to 1909 and 390 firmware and still have this issue. Previously it's my mouse freezing. Now it's the ethernet disconnecting. It doesn't matter which USB port I'm using.
