Surface Book 2 - Cursor freezes and mouse stops working randomly
2018-08-08T12:05:32+00:00
Hi there :)
I post this to know if some other people are getting this issue too with the Surface Book 2 (15" model here).
Since the last firmware / drivers update (August 2018 / link), my mouse (G502, connected via USB) randomly stops working after a few seconds / minutes. The cursor just freezes, and the mouse becomes unresponsive (while the mouse is still powered by the Surface). After a while, the cursor starts to move again as usual.
Depending on the battery mode, the random freezes are more or less frequent (more if I use max performance mode), as the mouse cursor movement has an influence on the clockspeed of the processor.
I tried my mouse on a Macbook Pro to see if it was hardware related or not, and it's not, the cursor didn't hang once while on macOS. So I guess it's software related (W10) since the last SB2 update ?
I also tried to switch between the two USB ports, same thing.
I tried to see if it wasn't related to a firmware update of my mouse via the Logitech suite, but no nothing has changed.
Any idea ?
Regards :)
Ps : Here is a link to the Reddit post I wrote (link)
EDIT :
Today I tried to uninstall the Logitech Gaming Software (used to customize the mouse), and until now it seems to fix the issue.
Actually, Logitech did an update of his software that I missed, so I installed it a few hours after I installed the Surface Book 2 firmware update.
Maybe the two are now incompatible ?
    2020-03-16T19:21:20+00:00
    Hey guys,
    Found a temporary fix.
    Under Device Manager you'll see an error under universal serial bus controllers. (USB). Disable driver and enable right after.
    I had to do this a couple times whenever it failed and so far today the mouse has been connected through out.
    Hope this helps.
    2020-04-08T03:05:29+00:00
    Tried disabling the driver under USB in Device Manager. This solution worked ok-ish for the first few weeks. Now after disabling it - it goes back to freezing and glitching straight away. Anyone found an actual solution to the problem? It's been 2 years Microsoft -.- c'mon
    2020-04-08T03:12:16+00:00
    I think there is a serious issue with their driver and firmware updates. Dissapointed
    2020-04-08T03:24:33+00:00
    Yeah it's been pretty ****. I've had numerous problems with my surface book 2. I kinda was expecting that considering that it was a second generation new tech but damn. It's too minor of a problem to be worth spending a month without a laptop to get it fixed(if it does get fixed at all) yet it is consistent and infuriating enough to drive you mad.
    Don't think I'll buy their hardware again :/ . On the plus side - they got the design part right I guess...
    2020-04-08T03:46:01+00:00
    I hate to say it but I don't think I will ever buy another microsoft piece of hardware.  Looks nice, works great when it works,  My conversation with a microsoft tech really infuriated me.  After nearly 18 hours of being dead to the world, no response, just as I was about to pack it up to ship it off.  I pushed the button one last time and it fired up.  I immediately called tech and the guy had the nerve to tell me to,  "think in the present"  "Its working now be happy"  He further informed me that if I sent it back and it worked when they got it they would just send it back to me.  I'm not a happy surface laptop owner!
