Surface Book 2 - Cursor freezes and mouse stops working randomly
2018-08-08T12:05:32+00:00
Hi there :)
I post this to know if some other people are getting this issue too with the Surface Book 2 (15" model here).
Since the last firmware / drivers update (August 2018 / link), my mouse (G502, connected via USB) randomly stops working after a few seconds / minutes. The cursor just freezes, and the mouse becomes unresponsive (while the mouse is still powered by the Surface). After a while, the cursor starts to move again as usual.
Depending on the battery mode, the random freezes are more or less frequent (more if I use max performance mode), as the mouse cursor movement has an influence on the clockspeed of the processor.
I tried my mouse on a Macbook Pro to see if it was hardware related or not, and it's not, the cursor didn't hang once while on macOS. So I guess it's software related (W10) since the last SB2 update ?
I also tried to switch between the two USB ports, same thing.
I tried to see if it wasn't related to a firmware update of my mouse via the Logitech suite, but no nothing has changed.
Any idea ?
Regards :)
Ps : Here is a link to the Reddit post I wrote (link)
EDIT :
Today I tried to uninstall the Logitech Gaming Software (used to customize the mouse), and until now it seems to fix the issue.
Actually, Logitech did an update of his software that I missed, so I installed it a few hours after I installed the Surface Book 2 firmware update.
Maybe the two are now incompatible ?
    2018-08-09T09:29:55+00:00
    No it doesn't fix the issue. Actually, setting it to max perf is worse for me :/
    I just sent an email to Logitech to see if they can replicate the issue.
    2018-08-09T09:34:30+00:00
    Just to be sure, could you confirm these things for me, please?
    1. Are you seeing this issue when running on battery (regardless of Battery powermode: Batterysaver, Recommended, Better performance, Best performance)?
    2. When plugged into AC power, are you seeing this issue when you bring the Powermode slider down to 'Recommended' or 'Better performance'?
    Best wishes,
    Razik
    2018-08-10T05:17:29+00:00
    Can confirm. I tried it with and without logitech drivers. It seems to "behave for a little bit" after removal. But comes back with the exact same issue.
    Have anyone found anything in the event viewer showing something happening when these glitches with the mouse happen?
    2018-08-10T13:24:18+00:00
    Nothing shows up in the event viewer :( But I'm not even surprised actually...
    2018-08-10T15:31:14+00:00
    Well this is unfortunate. Hope they look into the issue and fix it soon :)
    Regards.
    Razik
