Disabling 'Fast Start' immediately solved the problem. It can be found under power --> choose what the power button does. Click 'change settings that are not currently available'. No need for underclocking the power states or any other modifications. I then was able to upgrade to nvidia's current drivers for my machine as well. No freezes on battery or off battery.
Surface Book 2 - Cursor freezes and mouse stops working randomly
Hi there :)
I post this to know if some other people are getting this issue too with the Surface Book 2 (15" model here).
Since the last firmware / drivers update (August 2018 / link), my mouse (G502, connected via USB) randomly stops working after a few seconds / minutes. The cursor just freezes, and the mouse becomes unresponsive (while the mouse is still powered by the Surface). After a while, the cursor starts to move again as usual.
Depending on the battery mode, the random freezes are more or less frequent (more if I use max performance mode), as the mouse cursor movement has an influence on the clockspeed of the processor.
I tried my mouse on a Macbook Pro to see if it was hardware related or not, and it's not, the cursor didn't hang once while on macOS. So I guess it's software related (W10) since the last SB2 update ?
I also tried to switch between the two USB ports, same thing.
I tried to see if it wasn't related to a firmware update of my mouse via the Logitech suite, but no nothing has changed.
Any idea ?
Regards :)
Ps : Here is a link to the Reddit post I wrote (link)
EDIT :
Today I tried to uninstall the Logitech Gaming Software (used to customize the mouse), and until now it seems to fix the issue.
Actually, Logitech did an update of his software that I missed, so I installed it a few hours after I installed the Surface Book 2 firmware update.
Maybe the two are now incompatible ?
2019-03-27T01:22:08+00:00 -
2019-03-29T04:01:35+00:00 I am facing the same issues after update all the firmware, patches from Microsoft update. The recently week, freezes every few seconds!!!!!!
I tried several mice, same issues!!!
System Model Surface Book 2
Version 10.0.17763 Build 17763
System SKU Surface_Book_1793
Processor Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz, 2112 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Microsoft Corporation 389.2370.769, 10/2/2018
SMBIOS Version 3.1
System Type x64-based PC
2019-03-29T10:32:43+00:00 Had tried this fix, does NOT WORK!!
Fixing is super simple by 3 steps:
- Open Powershell with Administrator privileges
- powercfg -SETDCVALUEINDEX SCHEME_BALANCED SUB_PROCESSOR PROCFREQMAX 4000
- powercfg -SETACVALUEINDEX SCHEME_BALANCED SUB_PROCESSOR PROCFREQMAX 4000
2019-03-29T10:40:13+00:00 If 4000 doesn't work, try 3800. I have this issue just like you but this fix does helped a lot.
2019-04-07T08:02:42+00:00 Thanks. That works!
