Google Play
Surface Duo and Media Player for OneDrive Files
I have to download and store my music because I live in an area where there is little wifi access. I was able to connect my Duo to OneDrive and get the files to my Duo, but so far I have not been able to find a single MP3 player that can find the OneDrive music folder.
So far I have been through about a dozen players and they can play a file if I start within the OneDrive Music folder, but never find the folder to set up the library. All the players seem to go to the Android root folder and you are then stuck with no way to search outside that area.
Any ideas would be appreciated?
Surface | Surface Duo | Sound and camera
2020-12-31T14:27:26+00:00 -
2020-12-31T14:32:19+00:00 You just brought up something interesting. Along the way I remember buying and downloading a music player from my PC to the Duo (Google Play Site)
I wonder if this is where the player was that worked?
I just looked back at the Google Play site and I tried:
VLC
VLC for Android
Music Player by Green Banana
MP3 Player by MP3 Player
Deezer by Deezer Mobile
Simple Music Player by Simple Mobile
Music Player by Music Player
Music Player by Hemanth Savarala
Cloud Player by Doubletwist
Music Player by Dziania Rusak
Music Player by InShot Inc
Music Player by Mobile_V5
None of these seem to see OneDrive offline files
I have to go to work but will check back later, thanks for the help
2021-01-02T19:58:00+00:00 After much searching and hair pulling, I found that an APP titled CloudPlayer works and can find the local folder.
2021-01-02T21:21:33+00:00 I'm not sure why your VLC app didn't work for you. Mine worked perfectly.
2021-01-03T00:43:22+00:00 No idea but I found an answer so all is well, thanks
