Phantom Touch and Touch Dead Zone on Surface Pro 3
2015-04-02T16:12:19+00:00
Hi all,
I purchased a Surface Pro 3 (i5, 128 GB) 8 months ago (8/14) and had not any problem with it for 4 months. But one day (after some updates I think) the pen stopped working and I thought the batteries are drained. So I replaced them all (the coin and AAAAs) but the problem was not completely solved, the pen was detected and paired but after some minutes or seconds after windows log in, the pen cursor was disappeared from the screen and I had to restart the device or re-pair the pen to get it working again. Some other problems occurred simultaneously, phantom touch and touch dead zone! After changing the batteries, I saw phantom touches on the screen (approximately always on some specific points in the upper right quarter of the screen but not so annoying). Also I found a dead zone on the touch screen. (This area was a rectangle, parallel to the start menu of the Windows and contained the place of phantom touches and was not touchable by fingers but the pen could work on it).
I contacted the Microsoft Support Team and they asked me to install all updates. After doing that the only change was the appearing of a yellow triangle with an exclamation mark below theSurface Pro Touch Controller Firmware in the device manager. So I contacted them again, and they suggested uninstalling/re-installing the driver, rolling it back, 2-button shutdown and finally a Refresh. The first three options did nothing but fortunately after the refresh and update, the pen issue was solved. I think that the Touch Controller was fixed too, because the yellow triangle was gone. But still the issue of phantom touches existed, so I contacted them again, and this time they suggest a Reset. Yesterday I done the reset and update, but not only the problem was not solved but also has become worse. Previously I could work with the device even it had phantom touches but those were weak and with a lower frequency of occurrence. Now they are occurring with a higher frequency and are more destructive so that I can’t control the device under their attack! They close windows, select and delete Items, vibrate the screen, etc. Even they can trap the mouse cursor in fixed squares such as mouse-traps! Like before they are happening on constant points of the screen. (Mainly on 2 point: one in the top left corner (new) and another in the upper right quarter of the screen (as before)). Unhappily the dead zone of the touch screen has become bigger in comparison with before so that I can’t touch about half of the screen with my fingers and have to handle that with the pen. And the last negative effect of the reset was increasing the startup time of the Windows (I mean the time between appearing the Surface Logo and the Windows log in).
I can’t believe that this is a hardware problem because the device is never dropped or damaged, and for 3 or 4 months it didn’t have any problem.
Some other details:
  • A protector is attached to the screen from the first
  • I don’t have a Touch/Type Cover but usually a combo IR mouse/keyboard is connected via USB and with/without it situation doesn’t change.
  • Calibrating the touch screen or resetting its calibration doesn't help
  • Somewhere I road that the fluorescent and magnetic fields may interfere with display of Surface, so I’ve tried removing all nearby electronic equipments and turning off nearby fluorescent lamps, and even using different environments but nothing changed.
  • Phantom touches are happening completely randomly and in all application (metro, explorer, etc.). Sometimes they appear from the moment the device is powered on (even on Surface logo and Windows startup) and sometimes they appear some minutes after Windows startup.
  • I'm sure that this problem is not caused by any 3rd party application or any physical damage, but probably is caused by some updates.
  • Under heavy attacks of phantom touches only then pen can rescue the screen, when even the mouse is trapped or can't do anything!
I’m so disappointed, does anyone have any other suggestion/solution except the Replacement?
Abstract:
  • Problems exist: infuriating phantom touch, touch screen dead zone
  • Problems solved: random disappearing of pen cursor, problem with Surface Pro Touch Controller Firmware
  • Solutions tested: update, driver re-installation, re-calibrating the touch screen, 2-button shutdown, refresh, reset, turning off nearby fluorescent lamps, using different environments
Surface
Surface
The Surface family includes Surface Pro, Surface Laptop, and other Surface products. Surface is designed to help organizations, students, and consumers be more productive.
51 additional answers
    2016-08-01T14:36:23+00:00
    Yes, Halleluja indeed, and praise be to the Gods of the Internet. LanceDavis1989 ur a guru mate. This problem had basically made my SP3 useless, and i had owned it less than 2 weeks, and also had bought it from a fairly dodgy chain of second hand stores
    • forget abt MS Complete or warranty claims, they don't even stand behind a basic guarantee if u try to return something the next day. Paid £370 for an i3/64gb basic model, and was absolutely chuffed to find that, as i'm on a very limited budget, and a new one is out of the question for me. Was very happy with it, using it mainly as a device to read comics on, for which it is absolutely AMAZING. Better than the real thing. So to say i was GUTTED when this little problem reared its head is something of an understatement. The Phantom touches obviously make reading a comic quite impossible. Was so frustrated i had relegated it to the top of my wardrobe, because looking at it made me want to frisbee it across the room, lol.
    Now i think abt it, its quite possible that this issue was coming and going intermittently for the poor sap who owned it b4 me, and that's why they palmed it off on C@$# Generators.
    I literally had given up on the thing, and was about to buy a Chuwi Hi12 (cheap Chinese imitation) for £200 to replace it. This little fix worked like a charm, thank you so much. Very clever.
    It is appalling that Microsoft don't have their own solution, especially when it seems so simply done. This fix can even be run without Administrator Privileges!
    I would add that if this fix doesn't work for anybody first time, keep trying, because it took about 6 times, with a couple of reboots/2 button resets in between for it to work fully for me. Now and then its restorative powers seem to 'wear off' but another application sorts it out again. Computers man - you might as well pray, as try to work out why they do things sometimes!
    2016-08-03T14:00:26+00:00
    Perfect Solution Mr LanceDavid1989. I had almost lost hope as my device is out of warranty. But this completely resolves my problem. Many Many thanks!! :)
    2016-09-12T07:25:52+00:00
    Thank you so much! You've saved me from frustration with that link.
    My device is a SP3 Pro / Windows 10
    2017-02-09T21:50:16+00:00
    Hi LanceDavis1989,
    I tried the fix you suggested in your post. However, when I go to run it, my SP3 says that there is a .dll file missing. I tried downloading it and installing but still not working...
    Any thoughts?
