Hello GJTSimpson,
Thanks for posting your concern here.
Please give these troubleshooting steps a try to isolate the issue:
- Turn off and on Bluetooth on Settings.
- Check for Updates. On Surface Duo, tap Settings, tap System, tap System Update, and then tap Check for update.
- Restart Surface Duo. On Surface Duo, press and hold the power button until the Restart option is available and then tap Restart.
- Reset Network settings. On Surface Duo, tap Settings, tap System, tap Reset Options, and then tap **Reset Wi-Fi, mobile & Bluetooth.**Tap Reset settings to confirm that you want to reset the network settings.
If this answers your question, please let our Community know by marking this post as an answer. Otherwise, don't hesitate to respond to this thread if there’s anything else that needs to be addressed.
Kind regards,
StevenK
