Surface Pro 7 shutting down randomly
2019-12-20T02:39:27+00:00
If the device stays idle for a minute it directly shuts down. I have checked all the sleep and power settings and that's not an issue. I see this was an issue in previous versions too. **Any fix?**There are some answers to this which might have worked for some (marked as answer), but definitely not for everyone. If you face it, I strongly recommend returning it as the stress during this whole process is ridiculous and not worth it.
UPDATE:
After going through returning and rebuying 4 surface pro 7 devices (thanks to Costco). I decided to ditch it. The worst part is that Costco has essentially banned me from buying any laptops from them, even though I repeatedly told them that the devices were having issues.  I just loved the device for its utility and I really wanted it to work out. Microsoft and Costco should beashamed** of this.
The first 3 devices were returned in <1-2 months. The 4th one stayed longest (3 months), not because it was perfect but because of the pandemic. I loved the device in general. I was hoping I would not have problems with the 4th device. I did not have the random shutdowns but I started having
  • sudden blue screens with faulty_hardware error
  • the display would just temporarily turn off even though the machine is working(happened during a zoom call, when they could still see and hear me but my screen was black)
  • The s creen had a 2cm square with distorted pixels (picture), out of the blue while I was working. It went back to normal automatically
2020-06-30T19:12:55+00:00
Hey Everyone,
A fix is now available for the unexpected device shutdown through Windows Update:
Surface Pro 7 June 2020 update, https://support.microsoft.com/en-us/help/4526363/surface-pro-7-update-history
Surface Laptop 3 with Intel processor June 2020 update, https://support.microsoft.com/en-us/help/4526150/surface-laptop-3-update-history
BryanH [MSFT]
510 additional answers
    2021-01-29T16:24:18+00:00
    I purchased a Microsoft Surface Laptop 3 (13") at Best Buy in mid-January. It worked beautifully for almost two weeks, and then suddenly wouldn't turn on, despite being fully charged. Best Buy replaced it two days ago, in late January. The replacement, unlike the first one, prompted me for software updates. I loaded the first update, but did not get around to update number two. It was detached from power for short periods, but was working fine. While detached from power, it suddenly died, just like the first. I will be going back to Best Buy today to see what they can do for me. I really wanted this to be the right laptop for me and I'm very disappointed.
    2021-02-05T15:12:04+00:00
    HI,
    we've had our surface pro 7 for only a few weeks.  all updates applied and we still get this random shut down issue
    i have never heard or seen this type of issue on any device
    please advise
    thanks
    Paul
    2021-03-05T09:09:13+00:00
    Seems it's still there, after all theese months
    New Surface replaced from Microsoft because it was stuck on boot.
    The replacement unit (got three days ago) still reboots randomly in standby.
    The Intel Graphics Command Center trick doesn't work for me: applied yesterday, this morning it rebooted.
    This morning I updated the drivers from the Intel website
    2021-03-05T15:21:10+00:00
    My surface pro 7 occasionally goes to sleep at random times, even during my class Zoom sessions (I'm a teacher). It wakes up right away, but this has disrupted several class sessions this semester.
