Surface Pro 7 shutting down randomly
2019-12-20T02:39:27+00:00
If the device stays idle for a minute it directly shuts down. I have checked all the sleep and power settings and that's not an issue. I see this was an issue in previous versions too. **Any fix?**There are some answers to this which might have worked for some (marked as answer), but definitely not for everyone. If you face it, I strongly recommend returning it as the stress during this whole process is ridiculous and not worth it.
UPDATE:
After going through returning and rebuying 4 surface pro 7 devices (thanks to Costco). I decided to ditch it. The worst part is that Costco has essentially banned me from buying any laptops from them, even though I repeatedly told them that the devices were having issues.  I just loved the device for its utility and I really wanted it to work out. Microsoft and Costco should beashamed** of this.
The first 3 devices were returned in <1-2 months. The 4th one stayed longest (3 months), not because it was perfect but because of the pandemic. I loved the device in general. I was hoping I would not have problems with the 4th device. I did not have the random shutdowns but I started having
  • sudden blue screens with faulty_hardware error
  • the display would just temporarily turn off even though the machine is working(happened during a zoom call, when they could still see and hear me but my screen was black)
  • The s creen had a 2cm square with distorted pixels (picture), out of the blue while I was working. It went back to normal automatically
2020-06-30T19:12:55+00:00
Hey Everyone,
A fix is now available for the unexpected device shutdown through Windows Update:
Surface Pro 7 June 2020 update, https://support.microsoft.com/en-us/help/4526363/surface-pro-7-update-history
Surface Laptop 3 with Intel processor June 2020 update, https://support.microsoft.com/en-us/help/4526150/surface-laptop-3-update-history
BryanH [MSFT]
510 additional answers
    2020-07-15T13:42:37+00:00
    Are there any other Trend Micro users with this Surface random sleep and shutdown issue?
    https://success.trendmicro.com/solution/1119601-blue-screen-of-death-bsod-occurs-when-microsoft-surface-pro-exits-sleep-mode
    This is an issue from 2018 but uninstalled trend has completely fixed our issues.
    We are working through it with Trend.
    2020-07-21T06:51:29+00:00
    I have the same problem.  Also the brightness level changes slightly. It's really frustrating and diffucult to work on.
    I have all the updates to date and still have the issue.
    2020-08-07T01:54:30+00:00
    hi everyone. I do have the same problem since i used used july-2020 update.
    2020-08-10T17:48:29+00:00
    Sadly the June 2020 fix for the Surface Pro 7 did not help me.
    The only thing that helps is turning down the performance so it now runs slower than my iPro 4.
    Should never have bought this machine.  Huge waste of money and even bigger waste of time.
