Surface Duo eSIM is gone after update to Android 12
2023-07-12T09:11:41+00:00
my Surface Duo eSIM is gone after android 12 update and i notice the IMEI is changed adn it becomes the same imei as the NANO SIM. any idea hwo ti can happen ? and how to retrieve it ? also anywqay i can get the SIM 1 unlocked ?
Surface | Surface Duo | Install and update
    2023-07-12T13:15:41+00:00
    Hi Naga Natio.
    Thank you for bringing this to our attention.
    For your concerns I have send you a private message please follow the steps below and let me know your comments there.
    Please check your private messages on this site using the following steps:
    1. Click on your user name in the upper-right corner
    2. Click 'My Profile'
    3. On the right side of the page, click 'View Private Messages'
    Thank you
