Surface duo issue playing video
2022-03-24T20:53:03+00:00
why can't I play audio and video on my Surface Duo?
(Moved from CPC)
Surface | Surface Duo | Sound and camera
    2022-03-25T16:17:16+00:00
    (Moved from CPC)
    What type of audio and video are you trying to play, and what app are you using to play it? I have no issues play media on my Duo 2 and had none on my Duo 1 before I traded it in for the Duo 2.
    2022-03-25T17:16:49+00:00
    I should have been more clear with my question and appreciate your response. My problem playing video and audio only occurs when I've received audio/video texts. Playing youtube , IG, etc outside of messaging works. But not while in messaging. I've never had this problem on my Duo before so this problem only started recently and I can't recall any setting that I've changed that may have started this problem.
    I've reset the app settings to default and still doesn't work. Any advise is much appreciated.
    2022-03-25T17:31:00+00:00
    How did you "reset" the app settings to "default?"
    Are you using the stock Android Messages app or something else? Are all permissions for the Messages app enabled? I have Camera, Contacts, Files and media, Location, Microphone, Phone and SMS allowed. Also, try clearing the Messages app cache. Who is your provider?
