Surface Laptop very slow wireless connection
2018-03-17T11:05:26+00:00
Just bought a Surface laptop. windows and drivers are all updated. when i put it next to my lenovo thinkpad and connect to same wifi, i am getting 1/3 of the speed. I did multiple tests with same results. I searched all over the web to find an answer but nothing came up like mine.
processor :i7-7660U CPU @ 2.50 ghz
memory :16 ram
os: windows 10 pro 1709 (os build  16299.309)
Surface | Surface Laptop | Network
    2019-01-18T23:25:09+00:00
    I have a Surface Pro 4 and a Pro 6. After turning off Bluetooth my Upload speed increased by 3X on both Surfaces. Not using Bluetooth is not an acceptable option. Has someone provided an answer?
    2019-02-07T19:50:56+00:00
    Having the same issue as all above. Disabling/re-enabling the marvell avastar device fixed the issue temporarily, as did shutting off bluetooth. Nothing else seems to work. Other computers/phones on the same network show higher connection speed.
    Microsoft? Anyone? Seems this is a common issue effecting 1st gen surface laptops.
    2019-02-09T00:28:31+00:00
    I too am experiencing the same issue.
    2019-02-09T14:50:29+00:00
    I would hope MS would respond. IT is obvious this is a legitimate problem.
    2019-03-01T08:28:26+00:00
    Exactly same issue with my Surface Laptop . Another Dell laptop on same connection gets 200mbps , while mine is 20-40mbps . With or without bluetooth
