Surface duo stuck at 3 button navigation
2021-06-14T04:52:20+00:00
Cannot switch back to gesture navigation after I accidentally enabled the accessibility Menu. I cannot switch back to the gesture navigation enev after I turn off the Accessibility Menu, I tried resetting all app preferences, reboot the phone and nothing works.
Does anyone know how to resolve this? Thanks.
Surface | Surface Duo | Operating system
    2021-06-17T16:11:57+00:00
    Is the Gesture navigation option disabled as in you don't even have the ability to select the option?
    2021-06-17T16:24:35+00:00
    I can see and I can select the Gesture navigation option, but once I select the option, it appears to be in gesture navigation mode for a second, then it automatically switch back to the 3-button navigation mode.
    2021-06-18T23:36:12+00:00
    Same
    annoying  problem! !!
    2021-06-21T18:00:15+00:00
    We wanted to see if you could verify that the Surface Duo is up to date and then test to see if you can switch to Gesture navigation.
    If this does not work we would recommend performing a factory reset on the device after ensuring your device is fully backed up.
    2021-07-01T08:10:50+00:00
    I have solved this on my duo. If the magnification button is enabled then it forces the 3 button navigation as the magnification button is shown in the same content line on the screen.
    If you disable the magnification button in accessibility then you can go back into system >> gesture settings and select the gesture navigation option.
