Surface duo stuck at 3 button navigation
2021-06-14T04:52:20+00:00
Cannot switch back to gesture navigation after I accidentally enabled the accessibility Menu. I cannot switch back to the gesture navigation enev after I turn off the Accessibility Menu, I tried resetting all app preferences, reboot the phone and nothing works.
Does anyone know how to resolve this? Thanks.
Surface | Surface Duo | Operating system
    2021-06-17T16:24:35+00:00
    I can see and I can select the Gesture navigation option, but once I select the option, it appears to be in gesture navigation mode for a second, then it automatically switch back to the 3-button navigation mode.
    2021-06-17T16:11:57+00:00
    Is the Gesture navigation option disabled as in you don't even have the ability to select the option?
