I suspect the bugs are to do with Android 12 update. I could do the same as you but don't want to change phones if I can avoid it and from reports, a swap may not fix it. I'll be interested to see if it fixes it for you.
I cannot hear calls on my Surface Duo 2 unless on speaker phone
When I make (or answer) calls on my Surface Duo 2, the other person can hear me, but I cannot hear them unless I put the phone on speaker phone or use a Bluetooth device.
It worked for months and then stopped about six weeks ago.
I've updated all the software (including upgrading to the latest Android 12L), and I just did a hard reset. But still no sound on a phone call.
HELP!
Sam
Surface | Surface Duo | Sound and camera
2022-12-05T21:14:54+00:00 -
2022-12-05T17:53:56+00:00 I had this happen back in the spring, I think. A factory reset didn't do anything for me either. This was before the 12L upgrade, though. Unfortunately, I had dropped the device and the back glass near the camera bump was cracked. My only remedy was to get it replaced through warranty (though I had to pay ~1/2 the cost of the phone due to the physical damage not covered).
I'm not sure if that's what you want to hear, but that was my experience.
2022-12-05T13:32:24+00:00 We probably have different issues, or else you have TWO issues. My phone DOES send group texts and mms. It just doesn't have sound for phone calls unless I use speaker phone.
My phone is under warranty, and I finally contacted Microsoft (through the support on the phone itself) and they are shipping me a refurbished replacement and I'll ship them my defective phone.
Sam
2022-12-04T23:05:01+00:00 I've also got the same problem. As well as this, I am unable to send group texts or mms. This has all occurred since the last update to Android 12 (I think).
