Kinect v2 does not work with Surface Book with latest Windows 10 version1607
2017-03-13T22:04:07+00:00
Until recently I had no issues in using Kinect v2 on my Surface Book computer. Suddenly, after last week Windows and Surface Book firmware updates Kinect is not recognized anymore.
My configuration: Surface Book, i5/256
Kinect connected on the USB3 port of Surface Book
Powered either directly or via docking station
Kinect service set to use Nvidia card
Once I connect the USB cable the following happens:
  • Kinect led (from the Kinect adapter) is either orange (as no connection) or flashing white
  • After a few seconds, I get the following message popping up on the screen (message in the bottom right of the screen): "USB Device is not recognized...", followed up by the typical and infinitely repeating USB out sound
  • In Device Manager I can see under the Universal Serial Bus controllers: Unknown USB Device (Set Address Failed)
  • When I installed it first time the device was visible in the Devices, device Manager, etc. But was not starting the Kinect. After restart device was just not recognized.
What did I try?
  • from removing devices, disable, etc...
  • to reinstalling completely my Surface Book (yes... a few hours of work)
  • tested Kinect on a desktop PC - works OK
  • tested on a Surface3 even there works ok (I don't think that Surface3 has a USB 3 port... but, it works!)
  • used Kinect verifier, which as always is listing that USB device is unknown (but this is not new since I had it in the past too)
Any idea? I believe it has to do with latest Windows 10 updates, drivers and latest Surface Book update too. Thank you!
Kind regards,
Gia
    2017-10-01T10:35:00+00:00
    I still get this response from the Config Verifier, but I seem to be able to use the Kinect2 with 3D Scanner.
    (!) USB Controller
    "Unknown USB 3.0 port detected. Your configuration may support Kinect for Windows"
    (X) Verify Kinect Depth and Colour Streams
    "Insufficient frame rate detected from Kinect
    2017-10-01T14:53:19+00:00
    Thanks for the update.
    Does it affects the overall performance? Allow us to raise this to our developers. You can help us by sharing a screen grab or a photo of this error.
    Your cooperation on this issue is very much appreciated. :)
    Thank you.
    2017-10-01T22:57:31+00:00
    I'm not sure what the overall performance is supposed to be like. This is the first time I am using the Kinect 2.
    Screenshot here:
    https://1drv.ms/i/s!AnH\_pk8rQcZvh7seZAGUF81LFbzUOw
    The Depth and Colour Streams alternates between green, yellow and red for a while, but finishes on red.
    2017-10-04T12:43:22+00:00
    Thanks sharing the screen grab, Will. We'll take a look at this and have this checked by our Xbox Team and experts. Give us time to provide you feedback.
    Appreciate your patience on this one.
    Regards.
    2017-10-08T21:01:06+00:00
    This worked for me using the Surface Book but I had to connect the Kinect through a USB hub. The one I used was
    Plugable 7 port USB 3.0 hub - 25W Powered USB HUB with Two BC 1.2 Charging ports for Android, Apple iOS, and Windows Mobile Devices
