Same problem here!!!Just remind Microsoft does NOT fix this issue at all.and I was contact to Xbox and Microsoft support for a very long time.but it also cant work.very disappointed!!
Kinect v2 does not work with Surface Book with latest Windows 10 version1607
Until recently I had no issues in using Kinect v2 on my Surface Book computer. Suddenly, after last week Windows and Surface Book firmware updates Kinect is not recognized anymore.
My configuration: Surface Book, i5/256
Kinect connected on the USB3 port of Surface Book
Powered either directly or via docking station
Kinect service set to use Nvidia card
Once I connect the USB cable the following happens:
- Kinect led (from the Kinect adapter) is either orange (as no connection) or flashing white
- After a few seconds, I get the following message popping up on the screen (message in the bottom right of the screen): "USB Device is not recognized...", followed up by the typical and infinitely repeating USB out sound
- In Device Manager I can see under the Universal Serial Bus controllers: Unknown USB Device (Set Address Failed)
- When I installed it first time the device was visible in the Devices, device Manager, etc. But was not starting the Kinect. After restart device was just not recognized.
What did I try?
- from removing devices, disable, etc...
- to reinstalling completely my Surface Book (yes... a few hours of work)
- tested Kinect on a desktop PC - works OK
- tested on a Surface3 even there works ok (I don't think that Surface3 has a USB 3 port... but, it works!)
- used Kinect verifier, which as always is listing that USB device is unknown (but this is not new since I had it in the past too)
Any idea? I believe it has to do with latest Windows 10 updates, drivers and latest Surface Book update too. Thank you!
Kind regards,
Gia
2017-06-21T22:24:14+00:00 -
2017-06-21T22:36:29+00:00 Same here.
2017-06-21T22:40:17+00:00 Another bad news is, leap motion cant work on windows 10 now either.
2017-06-22T07:47:50+00:00 Thanks for taking the time to test it out Mick.
Its unfortunate that you confirmed what the rest of us have been experiencing, even with a fresh machine.
Also unfortunate that our friends from Microsoft here on the forum have gone quiet.
2017-06-23T06:01:29+00:00 Fellow Surface Book + Kinect sufferers -
This issue has also been raised on Twitter to @SurfaceSupport - https://twitter.com/SurfaceSupport/status/878114977147625472
Let's hope it leads to a fix.
