Pen taps registering as double clicks
2016-08-03T21:34:38+00:00
I installed a pending driver update on my SP4 yesterday and the anniversary update today. Now tapping with the pen registers as a double-click about 10% of the time, which makes pen input pretty much useless. The usual calibration options and settings in Settings, Control Panel and the Surface app didn't have any effect on this. I tried manually installing the latest SP4 drivers (8/3) but that didn't change anything, either.
This is also noticeable when drawing a continuous line. The The pen is suddenly detected as not pressed, and immediately again as pressed.
2017-06-11T15:59:16+00:00
Hey everyone,
I was like everybody, ever since I got my Surface Pro 4 my pen always randomly double-click while I tried to use touch keyboard.
So after I tried to search through all the forums and reddit. I stumbled into this site:
http://www.lovemysurface.net/remap-the-surface-pen-button/
Basically it lets you re-calibrate your pen.
-Simply type "calibrate" into your search bar and choose "calibrate the screen for pen or touch input".
-Choose "Setup" to first reset your pen by clicking the screen when prompt one time, then press enter after that to return.
-Choose "Calibrate" and then "Pen input".
-Use the pen to tap on the cross-hair point at the corner of your screen (It's kinda hard to find, but just follow the line and you'll see them eventually.
-After you are done, choose "Save"
This basically solve the problem for me, so I hope this help the others who are looking for a solution as well :)
Pruk
76 additional answers
    2016-10-01T16:48:30+00:00
    MS support was not helpful, at all. When I contacted them, all they told me was basic stuff like clean installing Win10, getting a new pen and sending my SP4 in for warranty exchange.
    I told them I did all that already and all they told me was "a clean install should fix this". I tried to tell them I clean isntalled several times already, and that a clean install will not downgrade the device's firmware, but they didn't believe me.
    Still, I think everyone should contact support to raise awareness of this issue. I'll contact them again next week, it's all I can do. I don't think they'll hand out a second replacement device.
    2016-10-04T03:39:50+00:00
    I reported the problem and opened a service request the first week in August, the problem was turned over to Global Escalation Services.
    Support has yet to find a cause, solution or workaround, they were unable to re-create the problem.
    Yes, I think it would be a good idea if there were more reports of the problem.
    2016-10-04T15:22:57+00:00
    I wonder if the fact that I have a screen protector on the Surface contributes to this problem?
    2016-10-04T17:58:05+00:00
    I also have a screen protector, did consider that but it worked fine and there was no problem prior to the July update.
