Pen taps registering as double clicks
2016-08-03T21:34:38+00:00
I installed a pending driver update on my SP4 yesterday and the anniversary update today. Now tapping with the pen registers as a double-click about 10% of the time, which makes pen input pretty much useless. The usual calibration options and settings in Settings, Control Panel and the Surface app didn't have any effect on this. I tried manually installing the latest SP4 drivers (8/3) but that didn't change anything, either.
This is also noticeable when drawing a continuous line. The The pen is suddenly detected as not pressed, and immediately again as pressed.
2017-06-11T15:59:16+00:00
Hey everyone,
I was like everybody, ever since I got my Surface Pro 4 my pen always randomly double-click while I tried to use touch keyboard.
So after I tried to search through all the forums and reddit. I stumbled into this site:
http://www.lovemysurface.net/remap-the-surface-pen-button/
Basically it lets you re-calibrate your pen.
-Simply type "calibrate" into your search bar and choose "calibrate the screen for pen or touch input".
-Choose "Setup" to first reset your pen by clicking the screen when prompt one time, then press enter after that to return.
-Choose "Calibrate" and then "Pen input".
-Use the pen to tap on the cross-hair point at the corner of your screen (It's kinda hard to find, but just follow the line and you'll see them eventually.
-After you are done, choose "Save"
This basically solve the problem for me, so I hope this help the others who are looking for a solution as well :)
Pruk
76 additional answers
    2016-08-18T13:20:41+00:00
    Got a replacement pen now. Still the same problem.
    2016-08-19T01:44:20+00:00
    I am also having this problem. What configuration of the Surface Pro 4 do you have?
    I have  SP4 i7 / 8gb / 256gb / Win 10 Version 1607 (build 14393.51)
    2016-08-23T20:51:58+00:00
    Same problem. Same build  except SP4 i5. Intermittent and annoying
    2016-08-25T12:02:29+00:00
    Same problem since newest firmware update. Tried a new Pen and reinstalling Win10, didn't help.
    SP4 8gb i5 256gb
