Pen taps registering as double clicks
2016-08-03T21:34:38+00:00
I installed a pending driver update on my SP4 yesterday and the anniversary update today. Now tapping with the pen registers as a double-click about 10% of the time, which makes pen input pretty much useless. The usual calibration options and settings in Settings, Control Panel and the Surface app didn't have any effect on this. I tried manually installing the latest SP4 drivers (8/3) but that didn't change anything, either.
This is also noticeable when drawing a continuous line. The The pen is suddenly detected as not pressed, and immediately again as pressed.
2017-06-11T15:59:16+00:00
Hey everyone,
I was like everybody, ever since I got my Surface Pro 4 my pen always randomly double-click while I tried to use touch keyboard.
So after I tried to search through all the forums and reddit. I stumbled into this site:
http://www.lovemysurface.net/remap-the-surface-pen-button/
Basically it lets you re-calibrate your pen.
-Simply type "calibrate" into your search bar and choose "calibrate the screen for pen or touch input".
-Choose "Setup" to first reset your pen by clicking the screen when prompt one time, then press enter after that to return.
-Choose "Calibrate" and then "Pen input".
-Use the pen to tap on the cross-hair point at the corner of your screen (It's kinda hard to find, but just follow the line and you'll see them eventually.
-After you are done, choose "Save"
This basically solve the problem for me, so I hope this help the others who are looking for a solution as well :)
Pruk
76 additional answers
    2017-09-10T22:12:31+00:00
    Hey everyone,
    Pruk
    This made my pen completely useless. It no longer pointed where you touched it to the screen. I had to reset.. I tried it three times all with the same results.
    2017-09-10T22:15:00+00:00
    Hey everyone,
    Pruk
    This made my own totally useless. It would no longer point to where it touched the screen.. I tried it three times. Luckily I could reset it back to its normal terrible functions
    2017-09-10T22:16:53+00:00
    agreed, calibration made everything way worse for me too..microsoft has to come up with an update..
    2017-10-19T01:12:34+00:00
    Sorry to say that the 2017 Fall Update seems to have made the problem worse, if anything - at least for me.
