Pen taps registering as double clicks
2016-08-03T21:34:38+00:00
I installed a pending driver update on my SP4 yesterday and the anniversary update today. Now tapping with the pen registers as a double-click about 10% of the time, which makes pen input pretty much useless. The usual calibration options and settings in Settings, Control Panel and the Surface app didn't have any effect on this. I tried manually installing the latest SP4 drivers (8/3) but that didn't change anything, either.
This is also noticeable when drawing a continuous line. The The pen is suddenly detected as not pressed, and immediately again as pressed.
2017-06-11T15:59:16+00:00
Hey everyone,
I was like everybody, ever since I got my Surface Pro 4 my pen always randomly double-click while I tried to use touch keyboard.
So after I tried to search through all the forums and reddit. I stumbled into this site:
http://www.lovemysurface.net/remap-the-surface-pen-button/
Basically it lets you re-calibrate your pen.
-Simply type "calibrate" into your search bar and choose "calibrate the screen for pen or touch input".
-Choose "Setup" to first reset your pen by clicking the screen when prompt one time, then press enter after that to return.
-Choose "Calibrate" and then "Pen input".
-Use the pen to tap on the cross-hair point at the corner of your screen (It's kinda hard to find, but just follow the line and you'll see them eventually.
-After you are done, choose "Save"
This basically solve the problem for me, so I hope this help the others who are looking for a solution as well :)
Pruk
76 additional answers
    2017-08-31T18:14:17+00:00
    It's weird that this annoying bug is STILL not fixed it's the ONLY issue i still have too but oh man how BIG this one is!
    2017-09-01T09:34:53+00:00
    And how about when you click on a word for autofill and it doubles the whole word after that point. And does it every time you back up and retry the word. I am starting to regret this purchase. I consider this a major issue for a touchscreen device. This bug is now over a year old and no sign of a fix. I am tempted write the Better Business Bureau for making consistently defective devices.
    2017-09-04T20:10:58+00:00
    I would like to get some official feedback from Microsoft on the issue.
    Suspected cause of the problem.
    Plans on correcting it.
    2017-09-10T15:49:13+00:00
    Do you think we can get some official feedback from Microsoft on the pen issue.
