Pen taps registering as double clicks
2016-08-03T21:34:38+00:00
I installed a pending driver update on my SP4 yesterday and the anniversary update today. Now tapping with the pen registers as a double-click about 10% of the time, which makes pen input pretty much useless. The usual calibration options and settings in Settings, Control Panel and the Surface app didn't have any effect on this. I tried manually installing the latest SP4 drivers (8/3) but that didn't change anything, either.
This is also noticeable when drawing a continuous line. The The pen is suddenly detected as not pressed, and immediately again as pressed.
2017-06-11T15:59:16+00:00
Hey everyone,
I was like everybody, ever since I got my Surface Pro 4 my pen always randomly double-click while I tried to use touch keyboard.
So after I tried to search through all the forums and reddit. I stumbled into this site:
http://www.lovemysurface.net/remap-the-surface-pen-button/
Basically it lets you re-calibrate your pen.
-Simply type "calibrate" into your search bar and choose "calibrate the screen for pen or touch input".
-Choose "Setup" to first reset your pen by clicking the screen when prompt one time, then press enter after that to return.
-Choose "Calibrate" and then "Pen input".
-Use the pen to tap on the cross-hair point at the corner of your screen (It's kinda hard to find, but just follow the line and you'll see them eventually.
-After you are done, choose "Save"
This basically solve the problem for me, so I hope this help the others who are looking for a solution as well :)
Pruk
76 additional answers
    2017-02-18T05:39:18+00:00
    My god i have EXACLY the same annoying problem too, i even purchased ANOTHER pen, same crap, purchased a NEW pen tip kit, same crap...changed the batteries, still crap...next step return the tablet back to best buy and let them go mad!!
    2017-03-26T18:14:50+00:00
    And I thought it was just mine.  Glad I'm not the only one.  I've had the pen replaced twice also.  Guess no one has found a fix yet?  It is very annoying, you need to read everything you typed before sending it to fix all the double letters.  I feel better knowing it's not just mine  :)
    2017-04-04T11:39:43+00:00
    Just  wanted to chime in, and say that I also have this problem.  I reinstalled the driver, and thought it was fixed.  It's not.
    2017-04-04T16:30:34+00:00
    Try deactivate Karspersky Internet Security
