Duo 2 Android 12L breaks calling
2022-10-28T08:22:25+00:00
Since the Android 12L update, I have not been able to make or receive calls. Incoming goes straight to voicemail and outgoing immediately ends calls. Carrier is T-Mobile. I suspect the issue is the same at what happened with the AUS phones as listed here Android 12 Breaks Calls — ZenTalk (asus.com)
This required an update to get the calls working again. Is there such as update in the works as right now my due 2 is just a tablet that cannot make calls.
Everything else works btw even calls with WhatsApp and teams
Surface | Surface Duo | Mobile connectivity
2022-11-04T01:05:31+00:00
Updated 12/8/2022 - Marking as "Answered" to raise visibility for now. We will update this response with more information.
Thank you for reporting this issue. If you are encountering this issue (incoming calls go to voice mail and outgoing calls end immediately), a fix has been released today, December 8th, and is available by updating your Surface Duo 2. For more information on how to update your Surface Duo 2 see Update Surface Duo.
Please let us know if this does not resolve the issue you are seeing. If it does not resolve the issue you are seeing, one thing to try is to temporarily insert a SIM from a different mobile operator and then change back to the SIM you are using. If you are encountering a different issue, please start a new thread by clicking Ask a new question in the upper right corner.
Here are the steps:
  1. Press and hold the power button for a couple of seconds, and then choose the Power off option to turn off your Surface Duo 2.
  2. Take out your current SIM.
  3. Insert a SIM from a different mobile operator (not your existing mobile operator).
  4. Press the power button to turn on your Surface Duo 2 and sign into your device.
  5. Once the device connects to the mobile network, press and hold the power button for a couple of seconds, and then choose the Power off option to turn off your Surface Duo 2.
  6. Take out the SIM and then place your original SIM back into your Surface Duo 2.
  7. Press the power button to turn on your Surface Duo 2.
If updating your Surface Duo 2 or the above steps do not help, please contact support for Surface devices by going to https://support.microsoft.com/contactus, click on the link to show the expanded list of products, then click Surface devices.
101 additional answers
    2022-11-06T02:08:13+00:00
    Same issue here. Duo 2 on Tmobile. Worked for a bit after the update and now immediately says "Call Ended" when I try to dial out and incoming calls go straight to voicemail. I don't really understand how this could possibly be a real issue that made it through testing. I love this phone but honestly the worst part of it is the actual phone functionality - either crappy reception compared to a Galaxy or it doesn't cleanly recover after coming back after being in a spot with no service.
    2022-11-06T07:53:11+00:00
    I'm actually in Australia on Telstra, and have experience call related issues. Restarting fixes the issue temporarily for me. Seems to get stuck trying to make a call. If a call is coming in, I occasionally get an audible ring, but no actual notification to answer the call.
    Again, restarting fixes it for a little while, but it does reappear.
    I don't believe it is T-Mobile related.
    2022-11-07T07:21:22+00:00
    I am also on Telstra and have been having the same issue today. I had to restart twice to make calls. I have now turned off WiFi calling to see if that helps at all. Hoping the November patch will fix this.
    2022-11-07T18:03:15+00:00
    ATT here.
