Hello rachel.olanoff,
Thanks for posting your concern here.
Please give these troubleshooting steps a try to isolate the issue:
- Run Bluetooth troubleshooter. Go to Settings > Update & Security > Troubleshoot > Bluetooth > Run the troubleshooter.
- **Run Surface Diagnostic Toolkit and check for Windows Update.**Restart the Surface after installing updates.
- Updatedrivers and firmware Check what is the current OS Build of your Windows version by typing winveron the search barnear the Windows logo.
Go
to **Download driver and firmware for Surface,**choose
(your Surface model) then click Download.
Choose the .msi file that matches or nearest to your current OS Build and
click Next.
After downloading, run and install the .msi then Restart.
If the issue persists, **Disable and enableBluetooth in UEFI.**See How to get to the UEFI settings on a Surface for more details. Once you're in UEFI, go to **Devices,**disable Wi-Fi& Bluetoothfor at least 15 seconds and then back to enable. Click Exit and Restart device.
Please let me know how the issue progresses by replying to this thread.
StevenK
