Edge not working on Surface Duo 2
2021-11-11T16:55:02+00:00
Every time I try to launch the Edge browser on my Duo II it comes up with a prompt to choose a profile, but before I can it disappears. Every. Single. Time. As such, I have been unable to use the Edge browser at all on my new device.
Christine
Surface | Surface Duo | Operating system
    2021-11-12T20:11:29+00:00
    I had the same problem. I rebooted, then got Edge to logon. It took a while after that for my favorites to sync, but they finally did.
