Surface Go 2 Main Camera - not functioning/installed
2020-06-03T21:08:06+00:00
Main camera is just a black screen.
Once an attempt to take a picture with the main camera generated this message:0xA00F4928<photocapturestarttimeout>
Rear facing (above screen) works fine.
Device manager only shows one camera: Intel(R) AVStream Camera 2500.
Have searched for drivers, Installed drivers from MS Surface Go 2 page all to no avail.
Fixable or return under warranty?
Surface | Surface Go | Sound and camera
    2020-06-28T15:02:27+00:00
    I'm having the exact same issue with my Go 2. Did you ever resolve this?
    Also, it's normal to have only one camera listed in Device Manager. I know someone with a Surface Pro 7 and two functioning cameras. She has only one camera (Intel(R) AVStream...) listed under Device Manager. So I believe that represents the front and the back.
    But maybe if Microsoft support chimed in they could clear things up...?
    2020-06-24T16:34:27+00:00
    Hello, MichaelContos!
    May we know how the front camera is on your Surface Go 2?
    By the way, did you visit this page to do all steps mentioned?
    https://support.microsoft.com/en-us/help/17444/windows-camera-app-webcams-help
    Is this happening on the built-in Windows Camera app?
    Can you try to see if you can take a photo using another app (Skype or any other app that has camera functionality you wish to use) or maybe try on a web browser then visit Facebook to see if you can take a photo from there?
    Looking forward for your response!
    Regards,
    Janette_Z
