Surface Dock not putting monitor to sleep
2016-05-11T01:50:28+00:00
Hi Everyone,
I have a new Surface Pro 4 with a Microsoft Dock and an Asus 28" Monitor for my GM. The problem I have is that when I shut down the Surface, the Dock seems to continue to provide power to the Monitor and the monitor doesn't go into standby mode. When I unplug the monitor cable from the dock it goes into standby but the moment I plug the cable (Display Port) back in the monitor powers up and says it can't detect the display port.
I have all current Microsoft updates so nothing recent has helped with this. Any thoughts?
Olin
2017-04-03T14:35:48+00:00
Ok, I am replying to my post about this because I have fixed my issue.
The way I fixed it was buying an ACTIVE mDP to HDMI adapter (one that supports 4K @ 60Hz) and using that with my monitor.  I have had no luck using the direct mDP to full DP cable.
Thanks for sharing, this solved my issue as well.  Monitor sleeps like a baby now.
For reference here are the adapter and cable I'm using:
Adapter: https://www.amazon.com/gp/product/B00PJ3LSIG/ref=oh\_aui\_detailpage\_o00\_s00?ie=UTF8&psc=1
HDMI Cable: https://www.amazon.com/gp/product/B014I8SIJY/ref=oh\_aui\_detailpage\_o00\_s00?ie=UTF8&psc=1
46 additional answers
    2017-03-29T20:45:24+00:00
    Have you tied using a different Surface Dock? If not we suggest that you do so. Also, if you are situated in the USA, we suggest that you bring your Surface Book and the Surface Dock to the nearest Microsoft Store to have it checked by one of our technicians.
    Feel free to post if you have other concerns.
    I've been active in the other thread about this, but figured I'd chime in here.
    I've tried this on two fully up to date SP4 docks, and both have the issue described in this thread.
    This issue doesn't occur when using an SP3 dock with the same Surface and monitor.
    The issue doesn't occur when plugging my SP4 directly in to the monitor using the DP on the device.
    If that doesn't point to this being an SP4 dock related issue, then I don't know what will.
    2017-03-30T16:18:21+00:00
    Just installed build 15063 (Creators Update) and it seems to have solved the problem for me. (keeping my fingers crossed)
    For those who want to try now and not want to wait till 11/Apr or later:
    https://www.reddit.com/r/Windows10/comments/62ayek/isos_now_up_for_insider_fastslow_pc_build_15063/
    BTW, this version has a built-in Night Mode which offers something similar to f.lux or other blue light filters.
    Cheers.
    2017-03-30T16:36:42+00:00
    Interesting!  I will try this tonight or tomorrow and report back.  I was fairly certain this was a FW issue with the dock.  I wonder if the Creators Update also comes with dock firmware, or if it's been an issue with the Surface Book or a Windows Driver all along.
    Interestingly enough, I tried connecting my Surface Pro 3 to the dock yesterday evening and the issue happens even with the SP3.  It's not running the Creators Update either though.
    2017-03-31T10:48:04+00:00
    Not sure if this is related...
    Win 10 14393 (AU) ->15063 (CU) Upgrade - Surface Pro 3 has much worse graphic performance now :(
    Just noticed the max resolution and refresh rate has changed on mine as well.
    Cheers.
