Surface Dock not putting monitor to sleep
2016-05-11T01:50:28+00:00
Hi Everyone,
I have a new Surface Pro 4 with a Microsoft Dock and an Asus 28" Monitor for my GM. The problem I have is that when I shut down the Surface, the Dock seems to continue to provide power to the Monitor and the monitor doesn't go into standby mode. When I unplug the monitor cable from the dock it goes into standby but the moment I plug the cable (Display Port) back in the monitor powers up and says it can't detect the display port.
I have all current Microsoft updates so nothing recent has helped with this. Any thoughts?
Olin
2017-04-03T14:35:48+00:00
Ok, I am replying to my post about this because I have fixed my issue.
The way I fixed it was buying an ACTIVE mDP to HDMI adapter (one that supports 4K @ 60Hz) and using that with my monitor.  I have had no luck using the direct mDP to full DP cable.
Thanks for sharing, this solved my issue as well.  Monitor sleeps like a baby now.
For reference here are the adapter and cable I'm using:
Adapter: https://www.amazon.com/gp/product/B00PJ3LSIG/ref=oh\_aui\_detailpage\_o00\_s00?ie=UTF8&psc=1
HDMI Cable: https://www.amazon.com/gp/product/B014I8SIJY/ref=oh\_aui\_detailpage\_o00\_s00?ie=UTF8&psc=1
46 additional answers
    2016-06-07T23:04:14+00:00
    Well I called them and they weren't able top help. They pretty much told me that this is normal. Ended up passing the buck to another department and I got fed up.
    When the Surface is connected, Is it really considered normal for a monitor to looking for a signal from a device while it is turned off?
    2016-08-20T08:39:01+00:00
    I have the same problem with a Samsung LU24E85KRS. It is connected with a Mini-DP to DP cable.
    Another (old) Samsung monitor connected to the same dock using a Mini-DP to DVI adapter and a DVI cable goes to standby gracefully.
    So it seems to be a problem with the DisplayPort implementation.
    2016-08-20T11:53:17+00:00
    That's interesting/good to know. I'm using a mini-dp to hdmi cable.
    I can try the mini-dp adapter to hdmi with an hdmi cable, and see how that goes.
    2016-11-10T15:27:09+00:00
    Did you find any resolution? Am having the same problem with a new monitor.
    It used to be okay with the previous one, and both are connected using direct DP without converters.
    But using a converter is not an option for me as only DP can handle the required resolution and refresh rate.
    Cheers.
