NEED HELP - EXCHANGE ACTIVESYNC (EAS) will not connect to Exchange Server
2012-10-28T22:11:06+00:00
We have two Surface RT machines.  Neither will connect to our 2003 Exchange Server with the Exchange ActiveSync setup (EAS) option in Mail.  We have lots of other Smartphones and tablets connected.  After many hours, Microsoft Surface Technical Support has not been able to resolve.
Errors received:
  1. "Unable to connect. Ensure the information entered is correct"
  2. A brief error message in the upper right corner of the screen that says ******@myOUTSIDEdomain.com is unavailable
Data Entered:
Using: Mail Tile/add your mail accounts/view all in set.../Other Account/Exchange ActiveSync (EAS)/show more details setup screen:
  1. Email address: ******@myOUTSIDEdomain.com
  2. Server address: webmail.myOUTSIDEdomain.com
  3. Domain: myINSIDEdomain
  4. Username: johnsmith
  5. Password: mypassword
Please let me know if you see something wrong with the above data - it works for about 40 other mobile device.
Surface | Other
2012-11-05T19:50:10+00:00
Wow, there is a lot of misinformation on this board..... Surface does connect to Exchange and has since day 1. The problem is that you are using self signed certificates, and surface does not accept self signed certificates unless you install them yourself. This is done for security, it had nothing to do with joining domains or anything like that, there is no bug. Exchange mail has worked on my surface since October 26th. Make sure you install the cert under
"Trusted Root Certification Authorities"
http://www.lonecpluspluscoder.com/2012/10/how-to-make-a-self-signed-ssl-certificate-work-with-windows-rts-mail-app-on-a-microsoft-surface-rt/
http://blog.brightpointuk.co.uk/adding-exchange-email-account-windows-rt
68 additional answers
    2012-11-03T00:34:23+00:00
    I assume this thread is still referring to just Exchange 2003 connections?
    I have 64G Surface RT and it connects fine to Exchange 2010 SP2 with just a few "push" reliability issues to resolve.
    From what I've read elsewhere, certificates need to be spot on to get it working.
    Steve
    Steve, an you explain? Since I never had any trouble connecting to my company's server before (iPad, iPhone, Blackberry, Droid), and never had to deal with this.
    Of course, the primary question is why do we need to deal with "just a few push issues" and "spot-on certificates" at all?!
    2012-11-03T00:52:26+00:00
    I guess the answer to why we have to deal with issues like this is that technology today is just too complex to test every aspect to the max... a bit like the old Intel chip that made maths mistakes and the iPhone that lost signal when you held it wrong.
    Pure guesswork here but when you connect your other equipment, does it moan about security certificates and give you the option to continue? I wonder if RT is missing the ability to allow invalid certificates.
    A lot of companies like to use internal certification servers for publishing SSL services like ActiveSync to the internet and if you don't have the enterprise certificate installed it will be considered invalid.
    The push issues I am seeing could be related to the network card going to sleep when it shouldn't ... but for a brand new attempt at tablet devices I don't feel that Microsoft are far off.
    I am the server admin for 6 Exchange servers at the UK college I work for and I am using a 3rd party trusted certificate. My servers are also on the latest rollup fix packages.
    It could be a number of issues, but certificates and versions is where I would start.
    Steve
    2012-11-03T01:23:03+00:00
    agreed. it all comes down to why do all the other devices work but not this. and if exchange is NOT supported, just come out and say it. don't provide the prompts and then throw out a vague error. also, MS support should know whether it's an exchange issue , or a domain issue.
    can anyone from MS say definitively that exchange is or is not supported?
    2012-11-03T02:40:49+00:00
    I think I have found the issue.  Not sure how to fix it though but I am hoping this will assist MS in fixing this issue so I can roll this out to my company.  Windows mail appears to only work with one certificate.  If you have a self signed certificate for authentication and another certificate to validate the website EAS will not work.  Eliminate one or the other and it works fine.
