Surface Laptop Studio will not charge occasionally / depletes battery at alarming rate.
2022-03-05T23:38:23+00:00
Every once in awhile my Surface Laptop Studio will refuse to charge - or atleast it says it's charging but clearly isn't. The battery then depletes at a rate of almost 1% every minute until in shuts off at 0%. Then I have to repeatedly restart it, plug in charging cable, for almost an hour to get it to start charging again. This isn't a charger issue. This is possibly some odd software issue.
Why Microsoft wants be to make a post instead of talking to an employee is beyond me.
Surface | Surface Laptop | Power and battery
2022-10-27T16:30:56+00:00
Marking as Answered to raise visibility - Updated July 17, 2023
Thank you for your patience and feedback as we worked on this. A fix is now available through Windows Update. After installing the update, please restart (not Shutdown) your Surface Laptop Studio. For more information about updates for your Surface available through Windows Update see Download drivers and firmware for your Surface
For more details about Surface Laptop Update History, please see Surface Laptop Studio Update History.
If the issue continues to occur, here is a workaround that has helped others start charging again:
  1. Connect your Surface power supply and make sure the power connector light is on.
  2. Save all your work and shutdown your Surface.
  3. Once shutdown, press and hold down the power button, you will see the Windows logo screen flash and then turn off, continue to hold down the power button (about 20 seconds) until you see the Windows logo screen flash again and then release the power button.
138 additional answers
    2023-03-20T22:50:57+00:00
    Mine now requires two solutions. One was the hard reboot, but now I’m running into an issue where that doesn’t work and an unplug, pause, replicas is required to get power. I suspect there’s more than one issue.
    2023-06-20T14:02:48+00:00
    I don’t blame you for returning. I definitely have buyers remorse and will never buy a Microsoft computer/non console product again based on the lack of support/response. Needing to spend another $100 to fix their broken equipment is… B#%%**$&&
    I believe there are two separate issues. I had rebooted just fine, but this solution suddenly stopped working and the frequency of the issue became multiple times a day. I can’t return so I purchased an appropriate usbc charger, which fixed my charging issue completely. I suspect the usbc bypasses both issues. One seemed software related the other hardware.
    Either way, if you can’t return (I highly recommend if the functionality isn’t a greater need, and you’re able to return the laptop) then going the usbc route is the “best” fix I have found. I’ve had zero issues since going this route.
    2023-08-06T06:47:30+00:00
    Finally - a solution that works. Have been struggling with this for 1,5 years.
    2023-08-12T11:25:49+00:00
    No one is patient anymore, and no one cares anymore because Microsoft treats its customers as a necessary evil and not only can't solve problems for over a year but pretends that there is no problem, does not offer anything for the problems caused, sends used laptops with the same issue, ignores customers and generally doesn't care.
    So please tell me why we should care about Microsoft.
