Surface Laptop Studio will not charge occasionally / depletes battery at alarming rate.
2022-03-05T23:38:23+00:00
Every once in awhile my Surface Laptop Studio will refuse to charge - or atleast it says it's charging but clearly isn't. The battery then depletes at a rate of almost 1% every minute until in shuts off at 0%. Then I have to repeatedly restart it, plug in charging cable, for almost an hour to get it to start charging again. This isn't a charger issue. This is possibly some odd software issue.
Why Microsoft wants be to make a post instead of talking to an employee is beyond me.
Surface | Surface Laptop | Power and battery
2022-10-27T16:30:56+00:00
Marking as Answered to raise visibility - Updated July 17, 2023
Thank you for your patience and feedback as we worked on this. A fix is now available through Windows Update. After installing the update, please restart (not Shutdown) your Surface Laptop Studio. For more information about updates for your Surface available through Windows Update see Download drivers and firmware for your Surface
For more details about Surface Laptop Update History, please see Surface Laptop Studio Update History.
If the issue continues to occur, here is a workaround that has helped others start charging again:
  1. Connect your Surface power supply and make sure the power connector light is on.
  2. Save all your work and shutdown your Surface.
  3. Once shutdown, press and hold down the power button, you will see the Windows logo screen flash and then turn off, continue to hold down the power button (about 20 seconds) until you see the Windows logo screen flash again and then release the power button.
138 additional answers
    2022-11-18T16:04:54+00:00
    The issue seems to be happening to me more than ever. It used to be every once in a while, now it's every single day, at least once a day. Absolutely abhorrent product and even worse support.
    You are in luck.
    I thaught everyone was having the problem at least twice a day like me !
    2022-11-18T16:19:57+00:00
    It's starting to be that much for me, so crazy!!
    Here's a suggestion to anyone thinking about buying Microsoft again, and what I would do in the future (though I don't think I'll be buying Microsoft again after this sh*tshow 🤣)
    Anyway BUY IT FROM COSTCO. Because Costco will let you return it with no questions asked, whereas MS only gives you 30 days. And then they will deal with Microsoft instead of us wasting our time.
    2022-11-18T16:22:31+00:00
    Mine started doing the same thing a couple of days back. I had a good run of luck, but that run seemed to have come to an end. I have reached the end of my rope on this issue.
    2022-11-18T16:43:25+00:00
    Here we go again, all I can do is wait helplessly for it to die so I can get back to work. Please can you all go file complaints with the Better Business Bureau against Microsoft, as I'm going to do as soon as my battery dies and restarts 🤣
