Surface Laptop Studio will not charge occasionally / depletes battery at alarming rate.
2022-03-05T23:38:23+00:00
Every once in awhile my Surface Laptop Studio will refuse to charge - or atleast it says it's charging but clearly isn't. The battery then depletes at a rate of almost 1% every minute until in shuts off at 0%. Then I have to repeatedly restart it, plug in charging cable, for almost an hour to get it to start charging again. This isn't a charger issue. This is possibly some odd software issue.
Why Microsoft wants be to make a post instead of talking to an employee is beyond me.
Surface | Surface Laptop | Power and battery
2022-10-27T16:30:56+00:00
Marking as Answered to raise visibility - Updated July 17, 2023
Thank you for your patience and feedback as we worked on this. A fix is now available through Windows Update. After installing the update, please restart (not Shutdown) your Surface Laptop Studio. For more information about updates for your Surface available through Windows Update see Download drivers and firmware for your Surface
For more details about Surface Laptop Update History, please see Surface Laptop Studio Update History.
If the issue continues to occur, here is a workaround that has helped others start charging again:
  1. Connect your Surface power supply and make sure the power connector light is on.
  2. Save all your work and shutdown your Surface.
  3. Once shutdown, press and hold down the power button, you will see the Windows logo screen flash and then turn off, continue to hold down the power button (about 20 seconds) until you see the Windows logo screen flash again and then release the power button.
138 additional answers
    2022-03-12T15:51:16+00:00
    Thank you for your update, KevinSurface. Do you see a heart icon on the battery logo when this happens?
    Please perform the USB recovery process on the device.
    This process will wipe everything out on your device and install a fresh operating system. Please make sure that you have back up your files and data either in an External Hard drive or use your OneDrive app.
    You’ll need a USB (USB stick) with at least 16GB/32 GB and format it clean (make sure that you have chosen FAT32 as the file system while formatting the USB). You'll need a PC running Windows 10 or Surface Device to download the system files/recovery image on the Microsoft Website.    Note: USB/Flash drives are the only required device for you to perform the follow steps below successfully.After formatting the USB to FAT32 USB, convert the FAT32 USB stick as a bootable device. Go to search > search for create a recovery drive > then follow the on-screen instructions. Please proceed to the steps below after converting your USB to a bootable USB stick:• Download the System Files or Recovery Image:1. Go to the Download a recovery image for your Surface.2. If you’re signed in with your Microsoft account, you will be prompt to choose the device from the list of devices on your Microsoft Account. If you’re not signed in, choose a product on the drop-down menu and provide the Serial Number of the device.3. Once the download is finished, go to the file, right-click and choose Extract all then choose the USB/Flash drive.
    • Perform the USB recovery:
    1. Shutdown the device by pressing/holding the power button for 10 seconds until it’s off.
    2. Insert the USB recovery drive into the USB port.
    3. Press and hold the power button for 10 to 15 seconds.
    4. Choose your language options and keyboard layout.
    5. Select Troubleshoot.
    6. Select Recover from a Drive. Choose Remove Everything and Fully Clean the Drive. Recovering this PC. If prompted for BitLocker Key, tap Skip this Drive.
    7. Select “Recovery”.
    I also suggest checking this out with a different original Surface Charger just to replicate if the issue will persist on a different charger.
    2022-03-14T16:42:43+00:00
    Hi John,
    I do not see a heart icon on the battery.
    I have tried the USB recovery and unfortunately, the issue still persists.
    I have yet to try it with a different Microsoft Surface power cord as it's a bit of a hassle to buy one at the moment, however I will try.
    From what i've read online this isn't an issue with the cord but the laptop itself unfortunatly.
    Thanks you again for the replies.
    2022-03-14T21:12:12+00:00
    I appreciate the details. In this case, please reach out to the Customer Support for further assistance. Visit our contact us page; https://support.microsoft.com/en-us/contactus/ to contact Microsoft Surface Support.
    If you're located outside the United States, you can check our Global Support Contact page; https://support.microsoft.com/help/4051701/. In contacting the Customer Support, see to it that you are on the right region by clicking the globe logo:
    2022-06-09T18:58:27+00:00
    I am probably a bit late to the party, but I have had this same issue with my Surface Book Studio on three separate occasions. One of those occasions was today, 9 June 2022. I plugged in the power cord when my battery was just below 40% charge. A bit later I noticed that my laptop had powered off and so I powered it back on. I got logged back in and noticed that the battery was sitting at 3% so I disconnected, inspected, and reconnected my power cable but to no avail. I ended up having to shut down the laptop. I waited about 5 minutes before I powered the unit back up. Upon logging in, I noticed that the battery was starting to take a charge.
