Surface Laptop Studio will not charge occasionally / depletes battery at alarming rate.
2022-03-05T23:38:23+00:00
Every once in awhile my Surface Laptop Studio will refuse to charge - or atleast it says it's charging but clearly isn't. The battery then depletes at a rate of almost 1% every minute until in shuts off at 0%. Then I have to repeatedly restart it, plug in charging cable, for almost an hour to get it to start charging again. This isn't a charger issue. This is possibly some odd software issue.
Why Microsoft wants be to make a post instead of talking to an employee is beyond me.
Surface | Surface Laptop | Power and battery
2022-10-27T16:30:56+00:00
Marking as Answered to raise visibility - Updated July 17, 2023
Thank you for your patience and feedback as we worked on this. A fix is now available through Windows Update. After installing the update, please restart (not Shutdown) your Surface Laptop Studio. For more information about updates for your Surface available through Windows Update see Download drivers and firmware for your Surface
For more details about Surface Laptop Update History, please see Surface Laptop Studio Update History.
If the issue continues to occur, here is a workaround that has helped others start charging again:
  1. Connect your Surface power supply and make sure the power connector light is on.
  2. Save all your work and shutdown your Surface.
  3. Once shutdown, press and hold down the power button, you will see the Windows logo screen flash and then turn off, continue to hold down the power button (about 20 seconds) until you see the Windows logo screen flash again and then release the power button.
138 additional answers
    2022-10-27T23:15:00+00:00
    If you do a hard reboot, that fixes the problem for me for a week or two. Also, agreed, nice to hear someone is finally looking into it. I’d love to be able to update my product reviews with positive news.
    2022-10-28T09:22:06+00:00
    Thank you very much, there's still hope within me that I won't sell this amazing laptop that I'm still paying for. Until then whenever it is, we'll keep rebooting for this charging and battery drain issue that comes along with it.
    2022-10-30T13:50:59+00:00
    I have the exactly same issue today, it start from 50% plus until drop to nearly zero.
    2022-10-31T00:55:53+00:00
    I turn off the SLS hard way and leave it off for one night, it start charge now. This problem needs to be solved, likely software bugs.
