BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED occurs regularly
2018-12-02T09:50:25+00:00
My new SB2 arrived on Wednesday. Since Friday I had the same bluescreen for 3 times by this morning. There is no system file mentioned and every time I have to hold the power button to make the device restart.
When the first bluescreen occurred, I was able to find new updates on Windows update (despite the fact that I had done basically nothing but Windows updates for the past 2 days), but the last 2 bluescreens occurred within the last 10 hours and I checked a lot, there are no updates avaliable. It doesn't seem to matter what I do in Windows to cause this bluescreen, the last one happened after I closed Outlook and stared at the desktop for a bit.
I have a MEMORY.DMP as well as an evtx file of all events registered since the boot and the last bluescreen, these events were only 7 minutes apart.
I also have noted information from the reliability monitor from the last bs.
Basically the last event (and the only event immediately before the bs) is Warning: Event 37: Kernel-Processor-Power (Microsoft-Windows-Kernel-Processor-Power) and the details are as follows (translated): The speed of the processor "7" in group "0" is limited by system firmware. The processor is in this limited performace state since 71 seconds (measured since the last report).
The last entry from the reliability monitor is: Unexpected Shutdown: Problemsignatur: Problemereignisame: BlueScreen
Code: 1000007e
Parameter 1: ffffffffc0000005
Parameter 2: fffff8011ce3dbc9
Parameter 3: fffff30ad219a548
Parameter 4: fffff30ad2199d90
Betriebssystemversion: 10_0_17134
Service Pack: 0_0
Produkt: 256_1
Betriebsystemversion: 10.0.17134.2.0.0.256.48
Gebietsschema-ID: 1031
Even with all updates installed, Surface Base 2 Firmware Update, Surface System Aggregator, Surface ME still report driver issues in the device manager. There seem to be no updates available for these.
I have read that this bs was caused by Avast AV once, and I use Avast AV, but I also read that the issue was fixed on their end.
I have MS Office ProPlus through my university, 2/3 times the bs occurred I was using OneNote for Windows 10.
Since I bought the 13 inch SB2 with 500 GB of storage at an extremely low price, a refund is not an option for me.
If needed I can provide the files mentioned and a list of programs I installed.
//Edit: Just had the 4th bs, again doing absolutely nothing but being on the desktop.
2018-12-04T21:07:22+00:00
Thank you for your feedback and the information you’ve shared.
Update 12/11: This is now fixed in the December 11, 2018—KB4471324 (OS Build 17134.471) update.
Symptom Workaround
After installing November 27, 2018—KB4467682 (OS Build 17134.441) update<br>some users may get a blue or black screen with error code “System thread exception not handled.” Resolution for this issue will be available in the December 2018 security update release. <br><br><br><br><br><br><br>For customers who are currently experiencing this issue please follow these instructions<br>Troubleshoot Bluescreen Errors and uninstall KB KB4467682. <br><br><br><br><br><br>Note for Surface Book 2 customers:  We are blocking this optional update only.<br>You will receive the required December 2018 security update release.
59 additional answers
    2019-02-28T23:37:40+00:00
    I have the same problem. Technical support could not fix it. Microsoft has no answers. It has been doing this since I bought it three weeks ago,,
    2019-02-28T23:57:44+00:00
    This issue has been fixed months ago, make sure you install all updates
    2019-03-03T12:22:07+00:00
    MS technical support remotely took over my SB2 and installed all updates. This still did not fix the problem. Then they did a factory reset. If it is fixed you need to retrain your technical support staff because they could not remedy the problem. I took it back for refund.
