BitLocker Issue after Updates Surface Book 2
2018-08-06T12:04:27+00:00
A few months back I purchased the new Surface Book 2 for a bit over 3,000 EUR. I had high hopes that as Microsoft knows this hardware inside out (just like Apple does with their MacBooks) I would not anymore have to go through the usual driver issues and what not but instead have a nice, reliable machine at hand that would make my everyday work life easier, not harder.
1. Sleep of Death
Before my holiday I then started using my old Dell notebook again, as there was no way, I could put this 3,000 EUR Surface Book 2 to hibernate (or sleep! - both did actually not work) without having to do press the power button thereafter for 20 sec or so and hardresetting the thing to wake up. It seemed to be the (what seems to be quite common actually!) sleep of death issue. In light of the many users seeming to have the same issues I was hoping Microsoft would get on to a firmware update during my vacation and all would be solved upon my return. In fact, after my return this morning there were about 20 or so updates that got installed after I powered the SB2 up, amongst them a firmware update.
2. Laptop Bricked after Update - for good!
After installing and restarting I then had this issue: https://answers.microsoft.com/en-us/surface/forum/surfbook2-surfupdate/surface-book-2-bricked-after-latest-firmware/06fb11b2-4eb2-4141-9cd1-1e02d54afd78 - A blue screen with a prompt to enter the BitLocker key. Well, I looked it up and seemed to have recovered the key in my MS account (luckily! as other users seemed not to be so lucky as can be read in the link above). The (almost funny by now) thing is, that my keyboard does not work. My touchpad works just fine, I can "change keyboard layout" or "skip this drive" (obviously of little use, as this drive is my system drive with my Windows installation on it). But when I click into the blank field to enter the key, my keyboard does not respond at all and I cannot enter a key.
3. Excel Pixelated Issue with Surface Dock
Did I already mention how much I like the idea to have my two 1080p monitors hooked up to my laptop via Surface Dock with just one magnetic cable? Well, Excel becomes almost unreadable and in general the (text) image quality is poor compared to my old Dell, which has a HDMI and a Mini Display port so that I can hook up the two displays directly. This is sad...
Microsoft, seriously? I had such high hopes that (after investing 3,000 EUR) I would finally get a machine that would give me the same reliability as my Mac Book Pro. You cannot ask these prices, offer a super fancy top of the nodge notebook and then have issues like this. I mean, my laptop is bricked! I am having nothing but issues with the thing, can't even close the lid (to slee or hibernate) without recovering all my files as the bloody thing goes into a sleep of death. WTF is wrong with this thing ... I thought the old days of bootable CDs (or USB sticks nowaday) were kind of over by now... especially after paying this price!
Any ideas how to get around this w/o investing half a day to re-install Windows and all my programs?
Had I not started to like the new Windows 10 and have many programs that need Win, I think I'd already be back to a Mac Book.
Thanks for your help in advance.
Moved from: Windows 10  / Windows update, recovery, & backup
2018-08-22T15:41:28+00:00
The Surface BitLocker Protector Check tool is now available to verify that the BitLocker settings are properly configured on your Surface Book 2 13” NVIDIA® GeForce® GTX 1050 and to help ensure that future updates go smoothly on your device.
For more information, please view our Known issues and additional information about Surface Book 2 article.
Updated 11/2/2018
98 additional answers
    2018-08-09T15:23:29+00:00
    Thank you, i was able to disable bitlocker after bubi's trick to boot into windows.  The other concern is that  dont know what is causing that bitlocker issue.
    I will try enabling it later and see if the problem will return.  If it does then ill have to return my surface book 2.
    2018-08-09T15:31:23+00:00
    Usually it happens after firmware/tpm updates. Why it loops I don´t know for sure. Do you want to use Bitlocker? Seems a bit exagerrated to return the device due to bitlocker loop. Could just disable it if it´s not necessary.
    2018-08-09T20:09:34+00:00
    OK Freminta I tried the command prompts, both options and it didn't work for me, thanks for your help anyway its appreciated. I detached the tablet and re started this worked.
    Now I am relatively computer savvy, compared to 80%of the people on this planet. So why would anyone on this planet buy one of these devices unless you are in the top 5% of Microsoft users..?
    I dont know if I need bit locker..  I just dont want to be locked out of it again after their next update. So I am going to turn it off.
    Begs the question.. why have it at all?
    2018-08-10T07:46:31+00:00
    What didn´t work with the commands? Did it give any message?
    If you managed to get it started just turn bitlocker off in settings, if you don´t know what it is, or know that you will need it, it´s no use having it on since it´s "advanced" for normal users.
    I don´t know why and I agree that if it´s activated automatically, it´s a bad idea. I was under the impression that it´s activated manually when setting up the device or after.
