Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-30T12:17:43+00:00
    It has turned into a mess, hasn't it?  The power manager is the same on all models to include the Surface Book series.  What 'fix' anybody uses on one will work on the others.
    The Windows Insider Preview works on all models and also works on regular PCs and laptop made by other PC makers (HP, Dell, Acer, etc.).
    The 'fix' will not be specific to any model, if that is what you are thinking about.
    If you can be patient, the next major upgrade should be coming across in just few days.  At this stage, I recommend to not make any changes and just wait for the upgrade.  The Firmware upgrade that came across for Insiders is still classed as "experimental" and there can even be a newer version coming out.
    Don't do anything, just wait (if you can).
    2019-09-30T12:33:00+00:00
    Can anyone confirm or deny that there is any fix/workaround relevant to the loss of battery on shutdown for the SP4 (not SP6)??
    The release preview appears to only be for the SP6 correct?
    Reading all of this is a mess.
    In short @MorganKita it is a temp fix.  In regards to what @James is saying he is emphasizing the Windows Insiders program with on going development of the @Surface line of Products & Windows, but off topic for a sec.  Even Apple is facing the same issue (Currently fixed on both their i9 series Macbook Pro's & recently the iPhone IOS 13.1)  So no it is not only INTEL CPU's, it's also ARM, AMD and others, it is the core programming of how the CPU can be programmed to help isolate malware for users.
    NOTE: Navigate to pg. 35 and look for the temp fix for SP4 with Jose, also yes be patient if you can, the next update will soon be avail. for the general public, along with further development of SMT with Firmware.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-30T13:04:10+00:00
    So "YES", Microsoft does hide some updates!
    No, this is not true. You can continue to debate this point, but if this is your
    experience, you need to file this as a problem report using the Feedback Hub
    App.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-30T13:07:27+00:00
    the firmware update is NOT tied to the operating system feature update. it will
    be listed separately. in your case, there might have been a bug. Jason Howard
    from the Windows team explained this to you in his reply. You are falsely
    setting expectations. You need to file a bug against Windows Update if you never
    saw a listing while checking for updates. Your screen shots show it as a
    separate update.
