Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-27T21:49:00+00:00
    Correction on my last - that is "Cumulative update" for which 1903 is already current version.  These usually come out to prepare for the next upgrade.  The next major upgrade should be coming out anytime soon.  Have not seen if there is a delay or not.
    2019-09-27T23:26:00+00:00
    Just to confirm that the recent firmware update from preview ring fixed my battery issue. Good luck for you all :)
    2019-09-28T04:00:25+00:00
    I can say the same thing now - no power loss and now my Laptop is showing it has about 7.5 hours of battery life which is a heck of a lot better than when I got it.
    Good to go!
    2019-09-28T04:10:23+00:00
    Good to go!
    Very nice @James.  Also drain more time like I had mentioned to Jose for a full cycle count...  Then you should be all good from there on.
