Well Barb, Jason may have a point which I forgot. Different Insiders are getting different builds. I am on the fast ring myself and mine, probably did come with it baked in. There is no record of the firmware being updated but yet I have the newer version.
No updates came across before or after the latest Build. There is no record of it and I watch closely of the Windows Update panel for a list of those.
As you mentioned before, Firmware updates "DID" install separately and in fact I would see those which causes the system to require a reboot before the Insider build would download. Not the case here and I may be getting this different build series which
may explain the sub-letters of the Build number. I kept wondering what those where because Microsoft remain "MUM" on everything.
I am getting a different build. It is the only thing that explains it.
When I used to program in the past, I used to do the same thing to incorporate new code if it became available before compiling the program. It reduces the deployment time but you do lose track of changes. Microsoft probably has these catalog in a fashion
to track them.
Right now, I have the machine turned off and unplugged. It went down to 84% and am looking to see if it stays at that same level when I fire it up again later tonight. If it does, we may finally have a fix to the power management system. It is not important
to myself since the machine is only used for the Insider Build testing and playing Age of Empires DE on it. I do have it configured for regular use but don't use it. I am keeping my Pro 3 RTM so that I can compare between the two.
But as for the updates, nothing else came across to include any automatic updates in the background. I can always spot those because the machine slows down when they come across and a Firmware update requires a reboot.
