Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-27T10:53:55+00:00
    So far I still have not had a recurrence of the 75% start up issue since installing the recent Surface firmware update released through Windows Insider. This might indeed be the long awaited fix.
    Even if it is fixed. I would really like to know what the actual cause/nature of the problem was, just out of curiosity.
    have you installed a firmware update from insider for which surface? Did you fix the battery draining?
    2019-09-27T11:11:01+00:00
    Surface Laptop 2, downloaded and installed via Windows Insider Release Preview. The only issue that has been plaguing me since August is my device always starting up with about 75% power after shutdown.
    Since installing this firmware, I’ve shut down my device about 3 or 4 times, including twice over night, and it has started up with 100% each time, exactly as it should.
    I will continue to monitor and report my findings here for at least a few more days.
    2019-09-27T12:55:03+00:00
    To update: This wasn't a permanent fix. I left it off overnight and woke up to 73% battery
    2019-09-27T13:04:04+00:00
    @ Johnny W Lam
    unfortunately, the installation of the .msi file re-proposes the 103.2614.257.0 update  in question and, therefore, I have the same behavior.
    I have to wait for new firmware update!
    Hey @Jose have you tried the the steps that I had proposed to you as I did for not only my own personal, but also for the Ent. units that I had fixed.  The units are a mixture of Personal and Enterprise units non are Win-Insider builds.
    Battery Config. = Best Performance with SMT disabled equals "~5-5 1/2 - 6hrs" indicated vs. 3-4hrs real world usage with wifi always connected.
    Battery Config. = Better Performance with SMT disabled equals "~6-7 1/2 - 8hrs" indicated vs. 4-5hrs real world usage with wifi always connected.
    Battery Config. = Best Battery Life with SMT disabled equals "~8-8.5 - 9.5hrs" indicated vs. 7-8.5hrs real world usage with wifi always connected.
    Performance degradation of course will take a hit with Best Battery Life vs Better Perf. with scaled back compute vs. Best Perf.  Max CPU fq.
