Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-26T21:05:43+00:00
    It may be too early to tell yet, but Microsoft sent out Build 18990 and came with the newer Firmware built in.  It has only been less than two days but with testing, have not had a power drop at all.  In fact, ran the machine (Surface Laptop 1st gen) for a little over an hour with general web browsing and email and it only dropped to 93%.
    Not sure if the Firmware is experimental and if is, not available for general download for others.
    Here is the Firmware that was installed:
    Good to know you are testing James 👍, but for current production machines facing the drainage issue, the fix for now is to turn off SMT via UEFI / Firmware Settings, build 1903 - 18362.356 - And from your description it seems back to the baseline norm, As conflict with current firmware does not handle super scaler well.  disable Simultaneous Multithreading (SMT) has units that I have tested operating normally as should.
    in my case, with surface pro 4, the deactivation of Simultaneous Multithreading (SMT) does not reduce the battery draining (which I have after the August 2019 update, during normal operation and not when the PC is off). From what I understand, it depends on the "Surface Embedded Controller Firmware - Firmware 103.2614.257.0 improves battery performance" update, which would have had to improve the battery performance and that, however, has worsened it. I hope that a new official firmware update will also be released for surface pro 4.
    2019-09-26T21:12:48+00:00
    in my case, with surface pro 4, the deactivation of Simultaneous Multithreading (SMT) does not reduce the battery draining (which I have after the August 2019 update, during normal operation and not when the PC is off). From what I understand, it depends on the "Surface Embedded Controller Firmware - Firmware 103.2614.257.0 improves battery performance" update. I hope that a new firmware update will also be released for surface pro 4.
    josèterra Surface Embedded Controller Firmware - Firmware 103.2614.257.0 is avail. for all Surface Pro machines download the drivers at the following Surface Pro 4 Drivers & Firmware - Download the appropriate version for your machine.
    Once everything is up2date, drain the battery completely and charge until 100% full and test.
    *For a visual understanding with Data Insights.  Look below.
    Prior to turning off (SMT)
    2019-09-26T21:25:26+00:00
    297/5000
    I apologize, I probably haven't explained myself correctly: since I installed that 103.2614.257.0 update, I have battery draining problems. Maybe, I could try to roll back the driver from device manager, but I'm afraid it could make the OS unstable, so I'm waiting for the new update.
    2019-09-26T21:29:40+00:00
    297/5000
    Can you take a screen shot of Device Manager and show all under system devices?
