Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-26T07:33:55+00:00
    My Surface Laptop 2 was just updated with firmware 145.501.139.0.
    No details on this update posted yet, will let you know if this fixes the battery fiasco.
    Same, SL2 and I just got this firmware update.
    I was 75% in charge when restarted and I was still 75% when back, but means nothing... I guess
    I'll see what will happens in next days.
    Googeling that firmware version, I find some new Reddit topics where seems it fixed the issue... but couple reply does not make a case :)
    2019-09-26T09:47:52+00:00
    I experienced no power drop this morning. However, I won't declare the problem fixed just yet. I've thought it was fixed before only to have it reemerge in a day or two. Let's all cross our fingers.
    2019-09-26T10:42:15+00:00
    Btw... IF and IF the issue is fixed, how can you unsubscribe form Windows Insider Programme?
    I thought with last update I got this sorted out, and I unlinked my account, and I thought I was unsubscribed, but later on I found that I had no account linked, but I was in the release preview ring and getting those updates.
    How to stop it? I just have to tick the "stop getting preview builds"?
    But when next major release gets installed, I've to remember to tick it again?
    thanks
    Carlo
    2019-09-26T11:02:13+00:00
    USE THE FOLLOWING AS A FIX.  LET ME KNOW IF IT WORKS FOR YOU AS FOR MANY.
    Battery FIX SURFACE FIRMWARE FIX AS OF 09.03.2019
