Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-24T16:47:39+00:00
    When I shutdown from the power menu, I unplugged the power and after switching back on after 30 minutes, it was still at 100%.
    What I'm specifically interested in is what happens when you charge to 100%,
    shut down at night and leave unplugged all night as to what the battery % looks
    like when you turn it on the next morning.
    2019-09-24T17:35:35+00:00
    This seems to have fixed the problem for me.
    I disabled hibernate, fully charged my laptop, shutdown, unplugged it, and left it for an hour. When I turned it back on it was still at 100%. Previously it was going from 100% to 75% even after being turned off only for a few minutes.
    Thank you very much Wahey03!!
    2019-09-24T19:03:17+00:00
    Is this with a Surface Laptop 2?
    *Edit to add*
    I just realized that I've had hibernation disabled this whole time, so that obviously isn't a fix/workaround for me. (shrug).
    2019-09-24T20:53:44+00:00
    I can confirm that the 100% to 75% battery drain after shutdown issue has been fixed on my Surface Laptop 2 by disabling hybernation.
    I need to test it for a few days to see how the battery holds up. So far so good.
